Main : Racing : Drag Z24 Oil Pan Sump
[<   Previous  23  24  25  26  27  28  29  Next   >]
Z24 Oil Pan Sump
Z24 Oil Pan SumpPopular
Submitterdatsa73More Photos from datsa73   Last Update2010/3/12 8:02    Tell a friendTell a friend
Hits583  Comments6    0.00 (0 votes)0.00 (0 votes)
girlbagsstore
Posted: 2010/8/24 14:03  Updated: 2010/8/24 14:03
 Re: Z24 Oil Pan Sump
Pendles
Posted: 2010/3/15 3:36  Updated: 2010/3/15 3:36
Just finished doing this with an A15 sump.
To check for leaks you can also cover the external welds with a light coat of plaster of paris, then fill the sump with diesel, any leaks will show up as discolouration of the plaster.
Cheers
Dave
unfamilia
Posted: 2010/3/14 2:09  Updated: 2010/3/14 2:09
thats a lot of cutting and welding.
you got may other z series sumps to spare?
D
Posted: 2010/3/14 3:03  Updated: 2010/3/14 3:03
Doesnt this amount of welding warp such sumps
that leaks become common?
Posted: 2010/3/14 6:47  Updated: 2010/3/14 6:47
Online!
The sump is bolted to an engine, before being welded back up. So warping is not a problem if careful welding is done.
datsa73
Posted: 2010/3/14 16:55  Updated: 2010/3/14 16:55
That is right. I pieced it together screwed to the board. Welded it, then had to cut it again from side to side. Bolted it to the block and weld it back up. I used a light in total darkness to patch up the pin holes. A lot a welding!
