Main : Racing When Hill Climbs Go Bad
[<   Previous  309  310  311  312  313  314  315  Next   >]
When Hill Climbs Go BadPopular
SubmitterNZ_dattoMore Photos from NZ_datto   Last Update2003/8/30 3:53    Tell a friendTell a friend
Hits6575  Comments16    0.00 (0 votes)0.00 (0 votes)
guess what happened...
Dak
Posted: 2003/9/1 11:45  Updated: 2003/9/1 11:45
 Re: When Hill Climbs Go Bad
Bugger, looks like you'll be needing another alignment from me Lemme know what you do and I'll sort you out an alignment.
NZ_datto
Posted: 2003/9/2 11:26  Updated: 2003/9/2 11:26
Thanks Dak, It will be a while before I start to fix it, as I want to get my Ute back on the road first.
NZ_datto
Posted: 2011/7/14 11:24  Updated: 2011/7/14 11:24
I thought I dig out this old thread!
It took a little while but I did fix this car!
Was worth it! It now has 250hp at the wheels so I have avoided the hill where I bent it in the first place though!
Posted: 2011/7/14 21:10  Updated: 2011/7/14 21:10
very nice. Not only have you fixed it, also you have improved it.
A car with that kind of unibody damage would almost certainly be scrapped here in USA, due to expense. Glad to see you saved it.
Wombat_racing
Posted: 2011/7/15 13:41  Updated: 2011/7/15 13:41
What brand are those wheels and what size are they??
PIGDOG
Posted: 2011/7/16 10:00  Updated: 2011/7/16 10:00
What's done to the engine?
D
Posted: 2011/7/17 8:54  Updated: 2011/7/17 8:54
From: under the Firmament LOL no twiglight effect BS
that heated alloy windscreen washer and radiator overflow looks similar to Jason`s
I like the lower stance at the back like the Escort asphalt
racers/rallye cars, its does improve weight distribution
NZ_datto
Posted: 2011/7/20 0:35  Updated: 2011/7/20 0:35
Hi the wheels are 15" Enkei's that I had resprayed. Not too sure of the model but they would about 10 to 15 years old.
The washer bottle and over flow have been made from Brushed Stainless steel and as for the engine its standard internals. I've upped the turbo to a T28, 440cc injectors and a Link (Vi-pec) G4 Ecu. The 250hp is at 18psi so I don't run that every day (usually 16psi) but I have managed a 12.89 1/4 out of it.
Cheers
Cam
D
Posted: 2011/7/21 2:57  Updated: 2011/7/21 2:57
Looks like a perfect all round package!
What are the laws there for engineering?
Are you limited in capacity turbo
eg. weight x 2.5 for turbo for cc
weight x 3 for NA for cc
the above is applicable in most states here
muke
Posted: 2003/9/1 7:39  Updated: 2003/9/1 7:39
looks like u'll need a new grill...speaking of grills...does ne one have one in mint nic....or at least straight, can get it painted or chromed...its for a sedan...this is the last part i need...cheers
muke
Posted: 2003/8/30 4:26  Updated: 2003/8/30 4:26
dude....ouch...i know wat ya feelin'
datsun120ycoupe
Posted: 2003/8/30 11:19  Updated: 2003/8/30 11:19
oh dear, I also know how that feels. I smashed up my old vk commy v8 last year
NZ_datto
Posted: 2003/8/30 4:06  Updated: 2003/8/30 4:06
and some more:
no
Posted: 2003/8/30 22:57  Updated: 2003/8/30 22:57
Noooooo! Is that your 4dr sedan? What are you going to do?
NZ_datto
Posted: 2003/9/1 3:52  Updated: 2003/9/1 3:52
I've been told is worth fixing, so I
stirlingmac
Posted: 2003/9/1 7:28  Updated: 2003/9/1 7:28
Good man, it does'nt look terminal.
