Main : Members : levey One for Mik
[<   Previous  66  67  68  69  70  71  72  Next   >]
One for Mik
One for MikPopular
SubmitterleveyMore Photos from levey   Last Update2010/4/24 12:11    Tell a friendTell a friend
Hits2440  Comments4    0.00 (0 votes)0.00 (0 votes)
There is probably a better place and way of mounting the switch but this works for me.
levey
Posted: 2010/4/27 9:04  Updated: 2010/4/27 9:04
 Re: One for Mik
I used the 70 degree switch.
Switches on at 82 degrees and switches off at about 76
Heat soak from top hose mounting made ne try the bottom hose, now I'm happy.
Anonymous
Posted: 2010/4/26 13:35  Updated: 2010/4/26 13:35
 Re: One for Mik
i can see your hose.wish i had a pick for you
so thats the 90deg one or the 70deg one? i like the zip tie action.
doe sthe fan switch on and off or does the heat in the coolant/hose (residula heat soak) force it to stay on always?
levey
Posted: 2010/4/26 9:17  Updated: 2010/4/26 9:17
 Re: One for Mik
I installed a VDO Temp guage and according to that the fan switches on at 82 degrees ( switch mounted on the bottom hose ).
