Main : Mechanical : Fuel Injection EGI Manifold
[<   Previous  86  87  88  89  90  91  92  Next   >]
EGI Manifold
EGI Manifold Popular
SubmitterddgonzalMore Photos from ddgonzal   Last Update2010/4/25 4:32    Tell a friendTell a friend
Hits3346  Comments6    0.00 (0 votes)0.00 (0 votes)
A PCV
B, C bolt bosses for diaphragm bracket
D Vacuum fitting
E bolt boss for cut-valve bracket
F Vacuum fitting
G bolt boss for pipe bracket
H Vacuum fitting to rail
I boss for accelerator cable bracket
J Accelerator Sensor (throttle position sensor, TPS)
K Fitting for hose
L Fitting for hose to Air Regulator (Idle air bypass)
M Fuel inlet
N Fuel oulet
O Fuel regulator
thomen
Posted: 2015/1/28 10:52  Updated: 2015/1/28 10:52
 Re: EGI Manifold
Just wondering where does K go to?
Cheers,
Tom
Posted: 2015/1/29 5:58  Updated: 2015/1/29 6:01
 Re: EGI Manifold
K goes to the IAC (Idle Air Control, the idle speed controller).
aka Idle control valve, electric Air Regulator
* K goes to IAC clean air inlet
* L goes to IAC bypass
see #21837
Posted: 2015/1/29 7:39  Updated: 2015/1/29 7:39
 Re: EGI Manifold
thomen
Posted: 2016/1/10 11:57  Updated: 2016/1/10 11:57
 Re: EGI Manifold
Just wondering if the 200sx 1980 models iac would be a suitable replacement? Is that the one you could hook to a stock ECU for idle up for ac AND cold starts?
=0&ck[idlist]=0&ck[viewcurrency]=USD&ck[PHP_SESSION_ID]=pub4dq8653svt7a2sna36ko1s6]rock auto iac
Posted: 2016/1/10 12:57  Updated: 2016/1/10 13:00
 Re: EGI Manifold
Yes, that's what the Datsun Idle Air Bypass does (fast idle control). Generically called IAC (idle air control).
Maybe the 200SX unit will work, it is the same electrically so the ECU works, but I don't know if it bolts to the B310 manifold. Look at the photos to tell?
EGI - Idle Air Bypass
I would check out locally available parts, from any Datsun EFI 1975-1988 including 280Z, R30, Bluebird, etc.
Posted: 2016/1/11 8:58  Updated: 2016/1/11 9:07
 Re: EGI Manifold
B310 EGI used 22660-H9205 REGULATOR-AIR ASSY
Idle Air Control (IAC) Valve
Standard Motor Product AC367 (direct replacement for Nissan #22660-N6910)
RockAuto.com fuel/air parts - 1980 Datsun 200SX (S110 Silvia)
AC367 looks like this
Looks similar to the B310 part. Notice the red screw, likely some kind of calibration setting. May be calibrated differently.
