[< Previous 232 233 234 235 236 237 238 Next >]
| Poster |
Thread |
| matty |
Posted: 2010/5/3 12:53 Updated: 2010/5/3 12:53 |
No life (a.k.a. DattoMaster)   Joined: 2003/3/28 From: brisbane Posts: 1880 |
 Re: Update May 2010 Mate that looks sensational!
Have you braced the arm internally?
| Poster |
Thread |
| retrorally |
Posted: 2010/5/3 23:19 Updated: 2010/5/3 23:19 |
Just can't stay away   Joined: 2007/8/2 From: Posts: 124 |
 Re: Update May 2010 No. I made the cut as close as possible to the pivot point on a 45 degree angle so hopefully they should be ok. They are 2 arms cut and shut to make one, the one arms behind are what is left. I have plated the full underside with 2.5mm sheet.
| Poster |
Thread |
| _Shmity_ |
Posted: 2010/5/5 7:05 Updated: 2010/5/5 7:05 |
Home away from home   Joined: 2006/9/26 From: Adelaide, SA Posts: 426 |
 Re: Update May 2010 why not make them adjustable. if you have the skill to extend them, making them adjustable just as easy.
| Poster |
Thread |
| retrorally |
Posted: 2010/5/5 8:58 Updated: 2010/5/5 8:58 |
 Re: Update May 2010 I just wanted them as strong as possible,I've got adjustable strut tops. If I have done my sums right the adjuster will be smack in the middle and if thats the case I might even go back to a standard top mount and only use the adjustables to help get me out of trouble if I hit something.
I'm not that keen on the 'T' bar arms.
The Z struts and brakes are also unbeleivably heavy.
