Main : Mechanical : Drive Train B10 3-speed 56-series
[<   Previous  448  449  450  451  452  453  454  Next   >]
B10 3-speed 56-seriesPopular
SubmitterddgonzalMore Photos from ddgonzal   Last Update2010/6/22 4:46    Tell a friendTell a friend
Hits2282  Comments10    0.00 (0 votes)0.00 (0 votes)
White: Bell crank clutch linkage (B10 only)
Green: Vent
Blue: Reverse lamp switch
Red: no shifter opening in extension housing
clyons8
Posted: 2010/6/25 15:17  Updated: 2010/6/25 15:18
 Re: B10 3-speed 56-series
Wow. 3 speed manual column shift (isn't it?).
I've only known of three 1000's in Australia with these fitted to them. A very hard to come by item indeed.
The three speed column shift automatic is fairly popular, but the manual 3 Speed column shift is really in it's own league.
Posted: 2010/6/25 17:10  Updated: 2010/6/25 17:10
Yes. I would say the only thing more rare is the 1200 column shift.
clyons8
Posted: 2010/6/26 2:04  Updated: 2010/6/26 2:04
Oh really? Was it a 3 speed also?
Posted: 2010/6/26 4:02  Updated: 2010/6/26 4:02
Yes. B110 3-speed has a clutch cable hole, while B10 unit has the crank type clutch.
B110 3-speed
B110 column shifter
elemental_funk
Posted: 2010/6/27 12:25  Updated: 2010/6/27 12:25
Here is a link to the article I have:
3 speed review
It has some interesting stuff about the ratios.
clyons8
Posted: 2010/6/27 13:06  Updated: 2010/6/27 13:06
Top stuff Finn, is that that Motor mag that's always advertised on eBay?
Sweet.
elemental_funk
Posted: 2010/6/27 14:14  Updated: 2010/6/27 14:15
Sure is. Just realised that its not that easy to read, if you want I can send you the hi-res pics. Cheers
Posted: 2010/6/27 18:23  Updated: 2010/6/27 18:24
Thank you that is great.
...while 6000 [rpm] is not exceptional as such, it will be constantly used in the [3-speed equipped] Datsun in first and second to keep up with other traffic
What they have produced is primarily a traffic car..so that slow motion motoring is as easy on the driver as possible
Page two:
elemental_funk
Posted: 2010/6/27 11:14  Updated: 2010/6/27 11:14
I have an article with a review of a b10 with a 3 speed. I'll put it up shortly
