Main : Members : mpower my prjct :)
[<   Previous  8  9  10  11  12  13  14  Next   >]
my prjct :)
my prjct :)Popular
SubmittermpowerMore Photos from mpower   Last Update2010/7/24 0:23    Tell a friendTell a friend
Hits2309  Comments6    0.00 (0 votes)0.00 (0 votes)
unshorttened toyota trueno ae86 lsd diff
b310gx
Posted: 2010/10/3 23:50  Updated: 2010/10/3 23:56
 Re: my prjct :)
I'd recommend you move the rear brake hard lines down & away from between the U bolt & the chassis rail. A couple of plastic cable ties should be enough. I can just see the chassis rail coming down on this & breaking one or both rear lines then no rear brakes. Those lines will take a little reshaping if you are gentle, so you could put a downward bend so that they run next to the U bolts, then there's no chance, the rail hits the diff housing first. Please don't be offended, as no offence is intend, but I've raced cars for so long, all sorts of things have happened, & failed brakes rates up there with the worst.
Edit - Oh by the way, that is one sweet little Sanitoro, always wanted one but I don't fit, due to long legs. Now if they only made a King Cab version, like my Navara.
mpower
Posted: 2010/10/4 1:04  Updated: 2010/10/4 1:04
 Re: my prjct :)
i leave it that way because of the tires, they are outside and they touch the rear panel first than the diff butt im working on the entire ute the fact is that the ute is a daily drive car and i have not much time, many thanks for the advise i was no offended because you never stop learning
cheers :)
greendog
Posted: 2010/7/28 13:40  Updated: 2010/7/28 13:40
 Re: my prjct :)
awesome any idea of the weight of it?will look mad with some bolt ons.need more track at the front now hey,anyshot of underneath?
Posted: 2010/7/29 2:28  Updated: 2010/7/29 2:28
 Re: my prjct :)
That's a lot of power lines. Is it in Santo Domingo?
mpower
Posted: 2010/10/2 17:00  Updated: 2010/10/2 17:39
 Re: my prjct :)
dont know the weight and yes i wan the bolt on´s for it, the front is going to be customize to :) & yes dd is in santo domingo :D
underneath pics
http://img299.imageshack.us/img299/8603/dscf4539.jpg
http://img824.imageshack.us/img824/1328/dscf4540.jpg
Posted: 2010/10/2 20:03  Updated: 2010/10/2 20:03
 Re: my prjct :)
