[< Previous 24 25 26 27 28 29 30 Next >]
Gearbox mount mods
levey 2010/11/27 8:45 Tell a friend
1966 5 0.00 (0 votes)
| If you compare a standard 56a mount to the photo you can see where I had to grind it for more clearance to fit the 60 series dogleg box. |
| Poster |
Thread |
| estyre |
Posted: 2010/12/14 9:07 Updated: 2010/12/14 9:07 |
No life (a.k.a. DattoMaster)   Joined: 2009/8/26 From: mandurah Posts: 3310 |
 Re: Gearbox mount mods try an auto coupe cable maybe ? they might be longer
i can messure the one out of my ute if you want ,ican compare the lengths between the cable out of my old sedan and the cable out of my coupe ?
| Poster |
Thread |
| levey |
Posted: 2010/12/14 8:38 Updated: 2010/12/14 8:38 |
No life (a.k.a. DattoMaster)   Joined: 2008/1/20 From: Perth WA AUS Posts: 9631 |
 Re: Gearbox mount mods I am using the cable that came with the car so I presume its the 56 cable, but it seems a bit long.
| Poster |
Thread |
| levey |
Posted: 2010/12/7 10:00 Updated: 2010/12/7 10:00 |
 Re: Gearbox mount mods Unfortunately I need to trim it a bit more, when the car is warming up and running rough it is touching the gearbox a bit, all good when its warmed up though.
| Poster |
Thread |
| estyre |
Posted: 2010/12/6 23:20 Updated: 2010/12/6 23:20 |
 Re: Gearbox mount mods nice work nigel looks pretty top notch !
| Poster |
Thread |
| evilsim |
Posted: 2010/12/13 12:26 Updated: 2010/12/13 12:27 |
Home away from home   Joined: 2003/11/30 From: Sydney.au Posts: 597 |
 Re: Gearbox mount mods i like it, good modding. saves lots of work using the stock mounts points too :)
p.s. i see you are using a speedo cable, is it from an 810 model datto, or are u using the stock one from the 56?? (i dont have a speedo atm due to cable length)
