Main : Misc K-roadster ( aka Chop Top 1000 )
[<   Previous  89  90  91  92  93  94  95  Next   >]
K-roadster ( aka Chop Top 1000 )Popular
SubmitterDMore Photos from D   Last Update2011/1/2 23:09    Tell a friendTell a friend
Hits3950  Comments12    0.00 (0 votes)0.00 (0 votes)
Low sitting position, Crutch busting welded doors,
Instant blow wave Eintein hairdo :)
lethal_john
Posted: 2011/1/6 5:08  Updated: 2011/1/6 5:08
 Re: K-roadster ( aka Chop Top 1000 )
lol i've never seen anything like it how olds that add?
i was half thinking of chopping the roof on the 2dr i got after seeing that photo and also doing the motorcycle engine conversion too
D
Posted: 2011/1/6 12:11  Updated: 2011/1/6 12:11
From: under the Firmament LOL no twiglight effect BS
2 R1 motors would be nice or even 2 900c engines
The old days had some crazy contraptions!!!
lethal_john
Posted: 2011/1/5 9:26  Updated: 2011/1/5 9:26
so by moving the wheel base forward do you mean making it larger or just moving it underneath the car forward? for better weight distribution for the larger motor??
D
Posted: 2011/1/6 2:12  Updated: 2011/1/6 2:12
Yes lengthen the wheelbase length so I have more
room in the engine bay. However a 6 cylinder with
6 mikuni carbs is probably overkill.
Better a straight 8 set of A10 engines with 8 carbs :)
or a WILDCAT SR a different type of SR engine made
with 2 x 4 cylinder paralleled together
ZigZag
Posted: 2011/1/5 8:25  Updated: 2011/1/5 8:25
do it
lethal_john
Posted: 2011/1/5 4:36  Updated: 2011/1/5 4:36
how would you do it d? would you use a ute or chop the top off a 2dr and get rid of the rear seats? maybe move the driver seat back a bit??
D
Posted: 2011/1/5 5:12  Updated: 2011/1/5 5:12
Id chop up a tudor for it has a floor that
accomodates the seats to go back a bit.
I honestly want to move the wheelbase
forward also using the original rails
so I can get a 370z 99inch wheelbase.
This will allow a nice engine bay and
not to mention improved handling and
bigger wheels if need be. Extra 20cm
should do it in case I want to run an
rb20 6 cylinder or L20B 6.
Id weld up the doors with extra tubing
extra tubing under the dash, to hold
the rear harness belts behind the seats
and to support roll over hoops or head
rest dooda. Also boot cut up and have
a clip on lid and maybe a tilt front end
for easy access to all bits and pieces.
ZigZag
Posted: 2011/1/4 23:29  Updated: 2011/1/4 23:29
i double dare you to make it D
D
Posted: 2011/1/5 1:12  Updated: 2011/1/5 1:18
I need a triple dare and someone
I can pay to do the serious welding
ZigZag
Posted: 2011/1/3 12:33  Updated: 2011/1/3 12:33
smoooooth
matty
Posted: 2011/1/3 12:11  Updated: 2011/1/3 12:11
Very cool mate
D
Posted: 2011/1/4 12:32  Updated: 2011/1/4 12:32
I gotta make it happen one day
