Main : Mechanical : Body and Interiors Front cut for motor
[<   Previous  2098  2099  2100  2101  2102  2103  2104  Next   >]
Front cut for motor
Front cut for motorPopular
Submitterdatsa73More Photos from datsa73   Last Update2011/1/21 4:38    Tell a friendTell a friend
Hits1243  Comments0    0.00 (0 votes)0.00 (0 votes)
Made the cut to fit the motor.
Planned this one out.  Made partial cuts, welded plate on one side across the cuts, drilled a hole through the plates on the other side, bolted it and welded a nut on the back side then finished cutting it out. Fits perfect!
Did you get that?   :)
