[< Previous 227 228 229 230 231 232 233 Next >]
| Poster |
Thread |
| ddgonzal |
Posted: 2011/2/20 9:33 Updated: 2014/4/3 2:47 |
Moderator   Joined: 2001/5/3 From: Kent, WA Posts: 31866 |
 Re: A-series Bell Housing B310 plate, about 3mm thick * 30411-H8200 PLATE-engine, rear
Dowels (2) * 30412-H1000 DOWEL-BLOCK TO TRANSMISSION D=9.5, L=15.5
HOLES Blue: 8.5 mm Red (dowels): 9.5 mm Green: 8.5 mm Gray: 11 mm (bottom two are 10x11 oval)
BOLTS Blue & green (6) * 08120-06065 4-speed, 08120-06010 5-speed ** hex bolt medium-strength, M08(?) x 60mm long (6) Gray Starter * 08121-03533 BOLT-HEX W/WASHER(M10 X 1.5) (2) ** medium-strength M10 x 35mm long (2) Gray bottom right * 08111-02062 BOLT-HEX HEAD WITH WASHER, COVER TO TRA ** M10 x 20mm low-strength Gray GUSSET Engine-to-gearbox * left side, bottom two holes (fits in from front) ** 08131-04010 56-series high-strength M10 x 40mm ** 08131-03010 60-series high-strength M10 x 30mm
| Poster |
Thread |
| lamb_daiquiri |
Posted: 2013/1/10 6:31 Updated: 2013/1/10 6:31 |
No life (a.k.a. DattoMaster)   Joined: 2009/4/30 From: Adelaide Posts: 1112 |
 Re: A-series Bell Housing That's cool! Where do you find this stuff?
| Poster |
Thread |
| ddgonzal |
Posted: 2013/1/10 7:02 Updated: 2013/1/10 7:02 |
 Re: A-series Bell Housing I made it myself with 3 sheets of paper and traced out the engine plate, then scanned it in.
It will print out exact size.
| Poster |
Thread |
| lamb_daiquiri |
Posted: 2013/1/10 8:22 Updated: 2013/1/10 8:22 |
 Re: A-series Bell Housing Nice work! Open source car mods in action.
