Main : Members : ddgonzal Flywheel holder for removing bolts
[<   Previous  127  128  129  130  131  132  133  Next   >]
Flywheel holder for removing boltsPopular
SubmitterddgonzalMore Photos from ddgonzal   Last Update2011/7/27 9:40    Tell a friendTell a friend
Hits2535  Comments4    0.00 (0 votes)0.00 (0 votes)
Used this method to hold the flywheel while I remove the bolts. It bent the bolt going to the block, but otherwise worked.
D
Posted: 2011/8/5 15:04  Updated: 2011/8/5 15:04
From: under the Firmament LOL no twiglight effect BS
 Re: Flywheel holder for removing bolts
I had something similar using L steel
with tube for the bolt worked the same
way but lost it and vice grips are good.
Cable_Tie
Posted: 2011/8/5 10:11  Updated: 2018/8/16 22:03
This lock is made from some 3mm steel welded together. Musta made it at least 10 years ago. Use a short bolt to mount to the back of the block.
To be honest, I can hardly ever find it when undoing a flywheel and end up using a prybar behind a transmission bolt or rattling the bolts.
LittleFireyOne
Posted: 2011/7/31 11:46  Updated: 2011/7/31 11:46
Nice idea, you could always find a tube to stick between the plate and block to take up some of the force
D
Posted: 2011/7/31 12:46  Updated: 2011/7/31 12:46
Love home engineering :)
I usually use 1 or 2 vice grips clamped on each side of fly
with two bolts in the similar places to stop any movement.
