Main : Mechanical : Wheels Rear Wheel Fitment
[<   Previous  63  64  65  66  67  68  69  Next   >]
Rear Wheel Fitment
Rear Wheel FitmentPopular
SubmitterddgonzalMore Photos from ddgonzal   Last Update2011/12/27 4:51    Tell a friendTell a friend
Hits2042  Comments2    0.00 (0 votes)0.00 (0 votes)
Keep in mind that tires are generally wider than the wheel they are installed on. Exception is "stretched" tires (tires fitted to rims wider than the tire manufacturer recommends).
In addition to the wheel width, allow additional 0.6" to 2.6" for tire width (allow zero extra for stretched tires).
Posted: 2011/12/27 0:38  Updated: 2011/12/27 3:34
 Re: Rear Wheel Fitment
My Sedan measurements:
Back Measure: 5.5 inch (140 mm)
Face Measure Right: 2-7/8" (73 mm)
Face Measure Left: 3-3/8" (86 mm)
So the wheelwell has an internal usable width of 213 to 226 mm.
So a 205 will fit, but will require a very exacting wheel offset. A 215 might even fit if fender lip is rolled.
Posted: 2011/12/27 3:38  Updated: 2011/12/27 3:38
Of course a little clearance is needed between the tire and spring, and between the tire and the inner edge of the fender.
Also take into consideration how far the rear axle moves side-to-side while driving.
