Main : Mechanical : Body and Interiors Zero offset does not center the tire
[<   Previous  1984  1985  1986  1987  1988  1989  1990  Next   >]
Zero offset does not center the tirePopular
SubmitterddgonzalMore Photos from ddgonzal   Last Update2012/1/6 23:44    Tell a friendTell a friend
Hits1712  Comments0    0.00 (0 votes)0.00 (0 votes)
Zero offset wheels offset the wheel outboard. Here this 8" wheel (with stretched tire) has 25mm clearance to the spring.
+15 wheels would tuck inside closer to the spring. +20 should even work (but maybe with occasionl rub on the spring with only 5mm clearance).
+30 would center it exactly, but these wide 8" wheels would then hit the spring. Or could use +30 with a 10mm spacer.
