Main : Misc Factory injection
[<   Previous  6698  6699  6700  6701  6702  6703  6704  Next   >]
Factory injection
Factory injectionPopular
SubmitterB120datMore Photos from B120dat   Last Update2003/10/17 1:23    Tell a friendTell a friend
Hits4911  Comments20    0.00 (0 votes)0.00 (0 votes)
this is "sunny" motor a15 factory injected, import sunny
sunny
Posted: 2003/11/14 14:03  Updated: 2003/11/14 14:03
 Re: Factory injection
nissan had these manifolds homologated for rallying and cams recognises this and holds a copy of the homologation papers my mate is still rallying his coupe had a set of papers for a b310.yeh it looks wimpy but it kicks . makes more power than my twin dcoe's did,more tunable , no i'm not going to try to explain it to you bighat you wouldn't understand
sunny
Posted: 2003/11/9 15:34  Updated: 2003/11/9 15:34
yeh the coils are behind the battery as is the igniter.they aren't after market, they are from a hyundai lantra (coils+igniter)the crank trigger is from an EL ford falcon(aus)
had to make a mount for the cramk angle sensor and the and pulse ring for the crank that was then controlled by the computer, it's not pretty but it works!they aren't that much more 120kg i think
tens_and_twenties
Posted: 2003/11/9 17:17  Updated: 2003/11/9 17:17
Any idea where to get one of these manifolds?
matbighat
Posted: 2003/11/10 2:27  Updated: 2003/11/10 2:27
Overall setupl looks pretty wimpy.
1200rallycar
Posted: 2003/11/10 6:50  Updated: 2003/11/10 6:50
i have one of these manifolds, make me an offer!
i have injectors fuel rail ect, all the wiring has been cut about 6inches long so i dont have the loom or computer, the throttle body is there but there is no AFM (i understand they are supposed to match the computer u get anyway)
this is it
dattoman_1000
Posted: 2003/11/10 11:00  Updated: 2003/11/10 11:00
$50
You have the address
1200rallycar
Posted: 2003/11/10 11:36  Updated: 2003/11/10 11:36
denied
MadTimo
Posted: 2003/11/10 12:08  Updated: 2003/11/10 12:08
$55
Seriously, how much will you take?
1200rallycar
Posted: 2003/11/10 12:18  Updated: 2003/11/10 12:18
big dollars, im not really sure, but i was gonna use it so i have to be convinced to let it go
ive heard these things are worth AUS$1000, i wouldnt expect one of the aussies to cough that up
but if it got anywhere near that i would let it go
Dodgeman
Posted: 2003/11/10 12:28  Updated: 2003/11/10 12:28
I'm just imagining it all polished up with custom plumbing, chrome, braided lines & anodised fittings,........ in my KB10.
Damn you man, you put ideas in my head that i can't afford. I have a Hemi to build instead.
Perhaps i will look at whats available in aftermarket TBI to use as carb replacements on my GX inlet manifold at a later date.
Chris
dattoman_1000
Posted: 2003/11/10 14:23  Updated: 2003/11/10 14:23
I know what you paid for it
I could quad TB my webber manifold for not much more
Pass
B120dat
Posted: 2003/11/11 2:06  Updated: 2003/11/11 2:06
simple answer to ur moeny problems dodgeman dont waste ur money on a Hemi spend it on the datto
Dodgeman
Posted: 2004/2/29 11:22  Updated: 2004/2/29 11:22
B120Dat
ANY money spent on a hemi is NEVER wasted. My engine is only the second known example of this particular model in Australia. I like the rarity.
Don't wory, the Datsun won't be left behind.
1200coupe
Posted: 2004/2/29 23:11  Updated: 2004/2/29 23:11
1200rallycar,
You are wrong, they are not worth AU$1000, whoever told you this is dreaming.
Also, you dont need the AFM to get this set up working, just blank it off and mount a cold air sensor in the inlet tube between the TB and the air filter. Then mount a water temp sensor in the thermostat housing, wire the whole thing to an aftermarket computer and run and tune the system to run open loop. In other words dont use a sensor head in the exhaust. That way you can map the computer how ever you want without the restriction of a closed loop system.
Sorry to be so blunt re your sale price
1200rallycar
Posted: 2004/2/29 23:51  Updated: 2004/2/29 23:51
oh well, that can happen, i'm happy to keep it for myself anyway
phunkdoktaspok
Posted: 2004/3/1 0:27  Updated: 2004/3/1 0:27
If you can get them for under $1000 let everyone know, I am sure they will be snapped up quickly ( when things are hard to get, the prices go up)
On an aftermarket computer you dont need an AFM if you use a Map Sensor ( usually mounted inside the computer)
All computers use water temp sensors, air temp sensors are not a necessity for operation. Oxygen sensor is required for closed loop operation. Closed loop doesnt restrict any program map from operating.
Closed loop only works at cruise anyway just like on factory computers.
Cheers Steve
olboy
Posted: 2003/10/17 10:01  Updated: 2003/10/17 10:01
where has the dissy gone
Will
Posted: 2003/10/17 10:44  Updated: 2003/10/17 10:44
Top left if I'm not mistaken...behind the battery
2332owner
Posted: 2003/10/17 11:05  Updated: 2003/10/17 11:05
There's no cap though... he's got an aftermarket electronic setup triggered off the crank.. check out the other pics.
1200rallycar
Posted: 2003/10/21 14:32  Updated: 2003/10/21 14:32
wow so much room
i mocked my injection on the other night with the a15 in and though sheez not very much room left for turbos at all, but this is a dream, pity those sunnys weigh too much or id be in one for sure
