Main : Mechanical : Body and Interiors Comparo Early vs 1200 alternator
[<   Previous  1858  1859  1860  1861  1862  1863  1864  Next   >]
Comparo Early vs 1200 alternatorPopular
SubmitterddgonzalMore Photos from ddgonzal   Last Update2012/5/10 9:23    Tell a friendTell a friend
Hits1446  Comments0    0.00 (0 votes)0.00 (0 votes)
Early 1000 alternator versus Datsun 1200 alternator (the later 1000 alternator has same mounting ears as the 1200 alternator).
Same front mounting face
Same diameter fan pully
Bottom mounting lugs differ
Depending on the engine, you could replace the Early type with the newer type by using a longer bolt (much longer) and a spacer (precision washers, or a stack or nuts, etc).
Anybody tried this, swapping newer alt on older bracket?
