Main : Mechanical : Body and Interiors Dual-Resistor
[<   Previous  1853  1854  1855  1856  1857  1858  1859  Next   >]
Dual-Resistor
Dual-ResistorPopular
SubmitterddgonzalMore Photos from ddgonzal   Last Update2012/5/13 2:40    Tell a friendTell a friend
Hits1339  Comments1    0.00 (0 votes)0.00 (0 votes)
22460-H7310 3-tap Ballast Resistor for CAL electronic ignition
Posted: 2012/11/21 23:29  Updated: 2012/11/21 23:29
 Re: Dual-Resistor
Used by 1975 B210 California model (and 1975-1977 280Z)
the terminal at far left is just a handy post to split the tach signal. It's not part of the resistor circuit.
An important thing to know about the early EI units is: Coil is never connected to 12V. It always goes through the resistor.
So anytime you see the dual-ballast resistor, be careful.
Factory Service Manual said:Quote:
During cranking, electrical current bypasses the secondary resistor, thereby connecting the ignition coil through the primary resistor.
