Main : Misc Konis for 120Y and Datsun bible
[<   Previous  6685  6686  6687  6688  6689  6690  6691  Next   >]
Konis for 120Y and Datsun biblePopular
SubmitterjaimecidpedroMore Photos from jaimecidpedro   Last Update2003/10/25 5:30    Tell a friendTell a friend
Hits4107  Comments11    0.00 (0 votes)0.00 (0 votes)
Better  performance than gabriel gas shocks.
Nissan4Eva
Posted: 2004/8/4 23:32  Updated: 2004/8/4 23:32
 Re: Konis for 120Y and Datsun bible
i got the shocks today and.....when i compress it, it goes down quite easy and when u try to extend it, it is very tough. Is that how these shocks are suppose to work?? if not what could be wrong.
ps. how do u adjust these kind of shocks?
B210sleeper
Posted: 2004/8/5 0:27  Updated: 2004/8/5 0:27
I have some of those dampers... the'yre dampers not shocks... they require the spring to extend them, they slow the spring's compression.
I also have a scan of the manual for 'em - pdf format.
Try this - 253KB
koni claims that those dampers last nearly forever.
Nissan4Eva
Posted: 2004/8/3 0:17  Updated: 2004/8/3 0:17
i was offered some konis like these, so i was just wondering if this type can be serviced.(Unsrew and remove piston etc.)
Team_Dat
Posted: 2004/8/3 3:22  Updated: 2004/8/3 3:22
Cool what is the part number, is it for the coupe or sedan?
benny
Posted: 2004/8/3 3:54  Updated: 2004/8/3 3:54
Try Koni part number # 80-2275 . They are adjustable.
cheers
Benny
Hop
Posted: 2004/8/3 4:20  Updated: 2004/8/3 4:20
Quite a regular
g'day benny,
can you tell me which model 1200 this part No. applies to?
i assume from the pic it's for the coupe but i want to be sure.
i was told a few years ago from the mob i tried to get them from that the koni's needed to be modified for the coupe.
cheers ben
matt.
benny
Posted: 2004/8/3 22:24  Updated: 2004/8/3 22:24
I use these Koni's in my coupe. They are un-modified.....although I also use lowered reverse eye leaf springs
cheers
Benny
Posted: 2015/6/11 23:29  Updated: 2015/6/11 23:40
Jaime had a Coupe, the only model which used stud-type upper mount and small-bolt eyelet lower mount. They should fit either a B110 coupe or a B210 coupe.
Jaime:
I just bought koni adj shocks for the rear of my coupe B210 ... The nissan motorsports number is (koni rear adjustables ) 99996-2359A , and the Koni numbers on the shock(koni terminology,not nissans) is:80A 2359.
Utes use eyelet mounts top and bottom.
Koni 80-2359 - coupe
Koni 80-2275 - unknown model
Nissan4Eva
Posted: 2004/8/3 17:03  Updated: 2004/8/3 17:03
excuse me if it may sound stupid, but can they be serviced/dismanled?
thanks alot.
benny
Posted: 2004/8/3 22:16  Updated: 2004/8/3 22:16
Yes they can.... but I would be taking them to a " Koni " specialist to do it.
Nissan4Eva
Posted: 2004/8/3 22:33  Updated: 2004/8/3 22:33
thanks...........
was checking as i'm buyin them second hand at a good price but i might need to service them after a year.
