Main : Mechanical : Drive Train 5 speed conversion 2 (71b)
[<   Previous  276  277  278  279  280  281  282  Next   >]
5 speed conversion 2 (71b)Popular
SubmittersikyneMore Photos from sikyne   Last Update2013/4/20 0:19    Tell a friendTell a friend
Hits1853  Comments3    0.00 (0 votes)0.00 (0 votes)
Another pic.
sikyne
Posted: 2013/4/20 0:36  Updated: 2013/4/20 0:36
 Re: 5 speed conversion 2 (71b)
This pic shows where i`ve welded a plate to mount the clutch slave cylinder.
Also shows where the starter bolts up to the standard 56A front section. you can see a bit of welding was required to fill a gap to the 71B housing at this point.
Posted: 2013/4/20 8:07  Updated: 2013/4/20 8:07
Nice. How does the release lever line up -- do you use the standard 56-series lever or the 71 series lever and throwout bearing?
sikyne
Posted: 2013/4/20 15:18  Updated: 2013/4/20 15:18
I used the 71 series clutch fork/lever and throw out bearing.
Also used the standard 71 series clutch slave cylinder.
The clutch pedal obviously had to be changed to hydraulic also.
