Main : Mechanical : Suspension KYB shock 07
[<   Previous  80  81  82  83  84  85  86  Next   >]
KYB shock 07
KYB shock 07Popular
SubmitterLittleFireyOneMore Photos from LittleFireyOne   Last Update2015/11/25 8:39    Tell a friendTell a friend
Hits1222  Comments0    0.00 (0 votes)0.00 (0 votes)
KYB #365007 Excel-G to suit GM Commodore 1978-1993
The supplied Gland nut will not fit on this example Stanza strut body (probly goes for others as well), if one were to have some Commodore strut bodies lying around they could always chop them up for parts etc otherwise you will have to modify your gland nut to fit the shock. Inside the gand nut is a ring of springy steel to locate the top of the shock a bit better, should be taken into consideration.
