Main : Mechanical : Body and Interiors Using Tachometer with ECU
[<   Previous  1334  1335  1336  1337  1338  1339  1340  Next   >]
Using Tachometer with ECUPopular
SubmitterddgonzalMore Photos from ddgonzal   Last Update2016/1/13 0:29    Tell a friendTell a friend
Hits815  Comments0    0.00 (0 votes)0.00 (0 votes)
Late Datsun tachometers (without the wire loop on the back) can be used with ECU tach signal
With some ECU you may need a 2.2K ohm resistor
