Main : Mechanical : Drive Train Adapter plate - 60L to 1200 gearbox mount
[<   Previous  121  122  123  124  125  126  127  Next   >]
Adapter plate - 60L to 1200 gearbox mountPopular
SubmitterddgonzalMore Photos from ddgonzal   Last Update2017/11/25 22:16    Tell a friendTell a friend
Hits1564  Comments0    0.00 (0 votes)0.00 (0 votes)
3 mm plate with four drilled holes
This may work with 60-series gearboxes. Similar to what levey did (although he welded the plate to the 56-series rubber mount). Is there enough room for the bolts?
Dimensions:
A - about 188 mm
B - about 195 mm ???
C - about 40 mm
The idea being that you bolt this plate to the bottom of the gearbox. Then fit the stock, unmodified 1200 crossmember in place with its rubber mount. Bolt up?
