Main : Members : 2332owner Installed 2
[<   Previous  48  49  50  51  52  53  54  Next   >]
Installed 2
Installed 2Popular
Submitter2332ownerMore Photos from 2332owner   Last Update2003/11/30 15:15    Tell a friendTell a friend
Hits3183  Comments9    0.00 (0 votes)0.00 (0 votes)
still chippin' away
Buff
Posted: 2003/12/2 0:17  Updated: 2003/12/2 0:17
 Re: Installed 2
This is still looking very impressive.
If only there was a way to get one of them booster setups from there to here.......................mmmmmm
john_13961
Posted: 2003/11/30 20:38  Updated: 2003/11/30 20:38
 Re: Installed 2
thats one sweet setup mate .if i may suggest that u install a heat sheild i had a unfortunate experience with 4 36mm mukuni smooth bore carbs on a coupe i had i left it idling as i opened a gate only to turn around to find the car on fire ... the cam shake caused the carbs to flood and yep u guessed it over the hot pipes ,but wow was it a fun thing when i had them tuned right , good luck n safe motoring
2332owner
Posted: 2003/11/30 23:43  Updated: 2003/11/30 23:43
 Re: Installed 2
They're Mikuni 45s. Thanks for the advise. I'm also running hoses from the overflows to the ground for safety's sake.
1200ute8u1
Posted: 2003/12/1 5:03  Updated: 2003/12/1 5:03
 Re: Installed 2
sweet looks really neet and shmick is that stainless exaust
2332owner
Posted: 2003/12/1 10:03  Updated: 2003/12/1 10:03
 Re: Installed 2
No it's Jet Hot coated... the rest of the exhaust is stainless though.
luv_my_68_wagon_1000
Posted: 2003/12/1 10:13  Updated: 2003/12/1 10:13
 Re: Installed 2
is that an A12?? Has the small radiator..looks sweet!!!!!
2332owner
Posted: 2003/12/1 10:46  Updated: 2003/12/1 10:46
 Re: Installed 2
It's an A14 bored to 1510cc. Stock radiator for now... I'll go 3 core later if needed.
D
Posted: 2003/12/1 23:57  Updated: 2003/12/1 23:57
From: under the Firmament LOL no twiglight effect BS
 Re: Installed 2
This is one of the best simplest cleanest setups Ive seen Okinawamericano well done.
Youre gonnna love the music those things make sucking the dinasour juice and making full use of it.
tens_and_twenties
Posted: 2003/11/30 15:30  Updated: 2003/11/30 15:30
 Re: Installed 2
Always wanted to try that... Unfortunately my brake master cylinder is in the way
Keihin or Mikuni? From a sportbike I assume?
