Main : Mechanical : Suspension VL Turbo caliper
[<   Previous  51  52  53  54  55  56  57  Next   >]
VL Turbo caliper
VL Turbo caliperPopular
SubmitterddgonzalMore Photos from ddgonzal   Last Update2017/1/18 1:30    Tell a friendTell a friend
Hits1290  Comments0    0.00 (0 votes)0.00 (0 votes)
Both are Girlock calipers
* GM VL Turbo (six-cylinder) fits 20 x 290mm rotor VENTED
* Datsun A10 Australia-assembled Stanza fits 12 x 245mm rotor NON-VENTED
20 x 290mm rotor
* VL V8, 6-cylinder Turbo
20 x 270mm rotor
* VL 6-cylinder non-turbo
* Uses a caliper that looks like the A10 caliper (non-finned) but is made for thick 20mm vented rotor
* Caliper uses same pads as VL Turbo, same piston. Difference is the fins and the shorter mounting lugs to match the small rotor
