Main : Members : kegs strut and brake 1
[<   Previous  131  132  133  134  135  136  137  Next   >]
strut and brake 1
strut and brake 1Popular
SubmitterkegsMore Photos from kegs   Last Update2004/1/2 14:25    Tell a friendTell a friend
Hits3419  Comments11    0.00 (0 votes)0.00 (0 votes)
please help me !!
muppet
Posted: 2004/11/13 9:06  Updated: 2004/11/13 9:06
Quite a regular
 Re: strut and brake 1
Some one will correct me if wrong but I'm pretty sure all the 1200 & 120Y use the same front springs just on different struts
Posted: 2004/11/13 16:31  Updated: 2004/11/13 16:31
B110 and B210 use different springs. See the chart about halfway down the Suspension & Brakes article:Quote:
B110
Spring coil outer diameter: 110mm (4.33 in)
Spring free length: 338mm +- 10
1977 US B210
Spring coil outer diameter: 100mm (3.94 in)
Spring free length: 375mm (388 w/AC)
rb20
Posted: 2004/11/13 22:39  Updated: 2004/11/13 22:39
i have b210 struts in my b110
and i had to the struts are the same but had to change the springs and strut tops
kegs
Posted: 2004/1/2 14:26  Updated: 2004/1/2 14:26
can anyone shed some light as to what strut this is?? the guy i bought it off says, its either stanza or sunny cant remember??? i wanna lower my car and this info will help me alot
john_13961
Posted: 2004/1/2 22:08  Updated: 2004/1/2 22:08
same brake pads as my sunny struts i have
Posted: 2004/1/2 22:50  Updated: 2004/1/2 22:50
This is the small "square" brake pads that the 1971-1973 1200 uses. The newer B210s and B310 (1975-up) have a wider "rectangular" pad of almost exactly the same design. Or am I looking at this wrong?
1200rallycar
Posted: 2004/1/3 0:43  Updated: 2004/1/3 0:43
it could be either, as the round headlight stanza and the sunny struts are the same
they are definately not the "good" stanza struts with girlock calipers and bigger discs
Posted: 2004/1/3 3:08  Updated: 2004/1/3 3:08
Anyone have a picture of the Girlocks?
All the US B310s got the regular Nissan brakes as in this picture:
b310 strut
However, we got the bigger brake pads.
kegs
Posted: 2004/1/3 7:46  Updated: 2004/1/3 7:46
so ive got the ####box ones?, ohh well they let me have 15's so cant be too bad. now does anyone know if stanze sprngs fill fit thesestruts?
1200rallycar
Posted: 2004/1/3 9:13  Updated: 2004/1/3 9:13
stanza 1200 and sunny all have the same spring diameter
problem may be in length though, i know the 1200 strut is shorter than stanza (square headlight) but i dont know where yours fit in, i would pressume they are the same as stanza (square headlight) but not sure
kegs
Posted: 2004/11/13 4:38  Updated: 2004/11/13 4:38
ahhh this is pissing me off, i wanna buy some new front brakes but dont know whether i need new struts or not, can someone tell me for sure what struts this is, its listed as sunny strut in tech section but to me doesnt look like it is please someone help me !!!!!
b310gx
Posted: 2004/11/13 4:59  Updated: 2004/11/13 4:59
take an old pad to a brake specialist & ask nicely if you can look through a brake pad book.most catalogues have a section with a
picture or sketch of the pads.just put the old pad over the sketch & compare.hint.wash the pad so you don't get brake dust all over the book.i had a sunny panelvan with this style caliper & i had to do this to get the right pad.somebody else mentioned 180b just recently,but i can't remember in which post,so that might be a go starting point.as for springs,i know stanza springs are longer than 1200,with sunny half way in between.the last set of front springs i had made were 100 the pair,from liverpool springs here in sydney,so why not see about
getting some new,heavier springs.just tell the spring seller,heavy duty,1 inch shorter.this will
drop the car 2 inches (50 mm) from standard.
if you go to liverpool springs,look for the picture of the maroon 120y on the wall.it belonged to a friend of mine,the car is long gone,reshelled as a 1200 coupe.
