Main : Members go_the_datto
[<   Previous  1704  1705  1706  1707  1708  1709  1710  Next   >]
go_the_datto
go_the_dattoPopular
Submittergo_the_dattoMore Photos from go_the_datto   Last Update2002/9/1 12:42    Tell a friendTell a friend
Hits6508  Comments6    0.00 (0 votes)0.00 (0 votes)
Here it is in and running. The motor has standard internals, standard carby and points ignition, so its not an expencive set up, and its a heap of fun to drive
jaimecidpedro
Posted: 2002/9/11 20:21  Updated: 2002/9/11 20:21
 Re: go_the_datto
I am missing the information here. Looks nice, is this a cold air box? or is it something else(turbo?)
Jaime
1200rallycar
Posted: 2002/9/12 6:16  Updated: 2002/9/12 6:16
 Re: go_the_datto
twin turbo, few discussions around, most called "tt a-series" (other pics too) also check link to "go_the_datto"'s site
1200rallycar
Posted: 2002/9/1 13:08  Updated: 2002/9/1 13:08
 Re: go_the_datto
what material is the carby box made from?
agr012
Posted: 2002/9/10 11:52  Updated: 2002/9/10 11:52
 Re: go_the_datto
as far as setup and tuning would you say that a single turbo would be easier? i ask because ive got twin carbs (which i can tune using a color tune and a manometer) and can see that twin turbos would probably be bitch to get flowing in unison .nice job, well detailled ... looks exellent
go_the_datto
Posted: 2002/9/14 2:06  Updated: 2002/9/14 2:06
 Re: go_the_datto
Good question, once you get the waste gates set up the same there no worries.
It took a bit of messing around but every system for controling boost I tried worked just some worked better than others.
