Main : Misc Transmission Tunnel SR20DET
[<   Previous  6527  6528  6529  6530  6531  6532  6533  Next   >]
Transmission Tunnel SR20DETPopular
SubmitterprodatMore Photos from prodat   Last Update2004/1/31 12:27    Tell a friendTell a friend
Hits4780  Comments6    0.00 (0 votes)0.00 (0 votes)
As promised the SR20DET transmission tunnel fabricated by a good mate. An S13 SR20DET box is being used with the handbrake relocated further back.
Cable_Tie
Posted: 2005/11/22 0:50  Updated: 2005/11/22 0:50
 Re: Transmission Tunnel SR20DET
What have you done with the Heater unit?
Grunterhunter
Posted: 2005/11/22 1:42  Updated: 2005/11/22 1:42
Good point cable tie- Its kind of difficult to grt a car registered without one. tunnel looks good though......
have you moved the engine position back so that it needs that extra box section where the heater should be? I thought you could do the SR conversion without messing with the firewall
prodat
Posted: 2005/11/22 2:21  Updated: 2005/11/22 2:21
The original heater was removed and replaced with a custom made one using a small thermo fan (switch operated). It makes the original look ordinary.
You can do the SR conversion without moving the firewall back, however...
1. The further back the better for weight distribution
2. More cooling available with the engine sitting further back
3. Allows for correct mounting of gearbox, i.e. the gearbox sits higher when the transmission tunnell is completed. Having the box parallel with the diff relieves stress on the tailshaft and unis.
matbighat
Posted: 2005/11/22 2:47  Updated: 2005/11/22 2:47
The heater mod sounds intriguing, tell us more ...
Exactly right about the SR20 aft placement.
Many have done the swap, but few have placed it optimally.
Grunterhunter
Posted: 2005/11/22 9:22  Updated: 2005/11/22 9:22
so presumably the shifter ended up another (50mm?) further back...... Did you leave it there or do something to bring the lever position forward?
prodat
Posted: 2005/11/23 3:12  Updated: 2005/11/23 3:12
Heater uses the original core, a new bracket and aluminium cowling were fabricated and it was connected up as per original (using a small thermo fan). The ducts go up through the dash as per the original design. Best heater yet.
The box sits a little further back (yep approx 50mm), the shifter is designed so that it brings the stick forward.
Hope that makes sense?
