Main : Members : datman55 H190 into Sunny
[<   Previous  101  102  103  104  105  106  107  Next   >]
H190 into Sunny
H190 into SunnyPopular
Submitterdatman55More Photos from datman55   Last Update2004/2/23 1:08    Tell a friendTell a friend
Hits1761  Comments4    0.00 (0 votes)0.00 (0 votes)
Rear end of the race car
datman55
Posted: 2004/2/23 1:11  Updated: 2004/2/23 1:11
 Re: H190 into Sunny
How's this for a Mongrel of a set-up....
H190 Housing, Nismo LSD Centre (from Stanza Rally car), Re-splined Axles, Nissan Pintarra Rotors (Slotted DBA), VL Commodore rear Calipers with custom made caliper bracket?
All fits under the rear end of the Sunny, of course I did have to put some flares on the guards
EDIT: You may also notice the bottom of the dry sump tank, and the new braided brake lines.
tsillay
Posted: 2004/2/23 5:05  Updated: 2004/2/23 5:05
 Re: H190 into Sunny
nice...
dude, trust me on this... fully baffle the axle tubes, and lift the filler plug up 1/2 an inch to increase the oil carrying capacity....This was standard on the 240 housings....I made the mistake of running a standard housing on the circuit once and once only!
If you can put some straight top arms and a watts or panhard on it, you wont believe the difference it makes.....all the nasty 'step out in high gears' stuff will just go away!!
I'll get you the measurements from the back of mine.. It took me years to get it right.....now if I could only get the front end as good....
datman55
Posted: 2004/2/23 5:17  Updated: 2004/2/23 5:17
 Re: H190 into Sunny
Thanks for the tips man, I will certainly do what you have suggetsed Re: Baffling, last thing I need to do is destroy one of the centres!
I will be adding a Watts link and straight top arms down the track, just trying to get the car on the circuit first, then I will start refining it! Our rules state that we have to run the standard top arms, but we can run super soft bushes in them (foam) to render them useless. I know this is a strange rule, and there has been plenty of controversy over it too! Either way, I would love the meausrements if you have them handy.
dattodevil
Posted: 2004/2/23 10:33  Updated: 2004/2/23 10:33
 Re: H190 into Sunny
Is this it? All I'm seeing is an X
