Main : Members : ddgonzal Fogged windshield ...
[<   Previous  232  233  234  235  236  237  238  Next   >]
Fogged windshield ...Popular
SubmitterddgonzalMore Photos from ddgonzal   Last Update2004/3/3 6:47    Tell a friendTell a friend
Hits3217  Comments11    0.00 (0 votes)0.00 (0 votes)
How to fix this?
ang94541
Posted: 2004/3/3 20:55  Updated: 2004/3/3 20:55
 Re: Fogged windshield ...
The stock fan just plain sucks. I'm sorry, but thats how i feel. And I'm sure the convoluted tubes that feed the defrost ducts are not helping.
I used to drive this Toyota Tercel ( sorry), if you turned on the fan full blast and directed the air to only come out of the center vents... it would defog the back window . That's the kind of power I want from my heater. I just can't figure out how to do it. The is almost no room behind the heater.
dattodude
Posted: 2004/3/3 22:18  Updated: 2004/3/3 22:18
A combination of opening the flipper windows and turning on the heat full, and fan full helps. Does the US model have a 2 speed fan?
Also remember that almost all 1200s are missing the vent garnishes,
Nick's Coupe at Adelaide
Cheers,
Chris
Posted: 2004/3/4 7:41  Updated: 2004/3/4 7:41
vent garnishes
I was wondering what was meant by those. I've never seen them before ... but this past weekend, I took some plastic bits and pieces out of the demister hoses. Now I'm sure it's what was left of the "garnish".
Did the garnish somehow help defrosting, or was it just finishing trim (for looks)?
Yes, North American 1200s have the two-speed heater fan.
The trouble with opening the wing/flapper side windows is that it is cold here (same temp as a refrigerator)! I do keep them cracked a little.
Quinn
Posted: 2004/3/4 11:05  Updated: 2004/3/4 11:05
what?!! a two speed fan I dont think either of my 1200s have fan speeds. Does anyone know if you can fit a later more powerful fan/heater setup out of, say, a later model nissan into a 1200?
Dodgeman
Posted: 2004/3/4 11:16  Updated: 2004/3/4 11:16
Quinn
The fan speed control switch is the heat[?] selector lever. It pulls out for speed control. Do you have a NZ owners manual? That should clarify the question on how many fan speeds you had in NZ
Quinn
Posted: 2004/3/4 11:37  Updated: 2004/3/4 11:37
oh that makes sense. the fan in my coupe mustnt work but i have noticed the sedans fan noise. still anyone know of a possable upgrade?
Astro_Boy
Posted: 2004/3/4 12:05  Updated: 2004/3/4 12:05
It took me a couple of months to figure out how to turn on my fan
There's a guy here in canberra who can get new garnishes for about $20 ithink. ( i dont actually know he gave them to me for free when i bought a bonnet cable from him.
If your interested i can look into it for you...
dattodude
Posted: 2004/3/4 12:52  Updated: 2004/3/4 12:52
Please do, the Nissan ones weren't cheap from memory. When you find out more, start a new thread.
Chris
kegs
Posted: 2004/3/3 11:59  Updated: 2004/3/3 11:59
yes id also like to know i almost hit a fallen tree last week becoz of this, lucky for my i only drove over it.
Dodgeman
Posted: 2004/3/3 12:06  Updated: 2004/3/3 12:06
It looks a lot like a partly blocked outlet grille, or duct. You need a warm engine for the heater to work properly, so i ask, how far had you driven when you took the picture?
dattodude
Posted: 2004/3/3 13:07  Updated: 2004/3/3 13:07
It does look like a blocked vent...but first....
Why is their so much moisture in the air in your car? wet floors from window leaks, are a REAL big problem in a Datto without Aircon. Also...look and check that the heater unit is not leaking!!..otherwise the heater/demister turns into a heater/humidifier.. which means a hot vapour of coolant gets coated all over the windscreen...pain in the ass to get it off!
Hope this helps!
Posted: 2004/3/3 16:49  Updated: 2004/3/3 16:49
I'd been driving for 10 minutes, and the engine was fully warm by this time. As you can see, the center of the windshield as demisted, but not the sides of the windshield.
Why so wet? It's Seattle, man, cool and damp, but not even raining. My first 1200 did exactly the same thing.
Newer cars don't have such a problem. Does the 1200 need a bigger fan? Faster fan? Reshaped duct outlets?
