Main : Members : Team_Dat Look what I found!!!!!
[<   Previous  1  2  3  4  5  6  7  Next   >]
Look what I found!!!!!Popular
SubmitterTeam_DatMore Photos from Team_Dat   Last Update2004/3/7 10:14    Tell a friendTell a friend
Hits4379  Comments20    0.00 (0 votes)0.00 (0 votes)
i dropped the oil in my diff today cos i had a noise and there was a slight leak from the filler plug (time for some Teflon tape) and tyhis came out with the oil
Dodgeman
Posted: 2007/7/11 16:55  Updated: 2007/7/11 16:55
 Re: Look what I found!!!!!
Back in Marck of ;04 when I wrote that post, I was not aware that early 120Y's used the H145, but have learned it since.
Thanks for the reminder,
crzy_1200_ute
Posted: 2007/7/12 2:37  Updated: 2007/7/12 2:37
:) i say it just means go faster
faster you go it doesnt have time to break haha :)
nzdattoman
Posted: 2004/3/19 10:38  Updated: 2004/3/19 10:38
giving datsuns they are
B120dat
Posted: 2004/3/7 10:25  Updated: 2004/3/7 10:25
YIKES!!!
kegs
Posted: 2004/3/7 11:05  Updated: 2004/3/7 11:05
hmmm, funny place to find 20 cents
Team_Dat
Posted: 2004/3/8 2:38  Updated: 2004/3/8 2:38
no the twenty cents was for size reference
pretty scary
got a nasty whine now
1200coupe
Posted: 2004/3/8 6:30  Updated: 2004/3/8 6:30
It looks likes a part of one of the locking tab washers off the bolts that mount the gear to the centre.
Team_Dat
Posted: 2004/3/8 6:38  Updated: 2004/3/8 6:38
is that bad?
can my diff go pop?
1200coupe
Posted: 2004/3/8 6:48  Updated: 2004/3/8 6:48
Thats the million dollar question????
Might be worth dropping it out to check the basic bits are all OK.
Just remove the tailshaft at the diff, disconnect the handbrake stuff if you have it, drain the oil, remove rear wheels and brake drums, undo rear axle bolts, pull the axles out, then unbolt the diff centre and take it out and put it on the bench. The piece is big enough to find where it came from, just have a good look and you will find if there is a problem.
It's about as easy as that.
Team_Dat
Posted: 2004/3/8 8:38  Updated: 2004/3/8 8:38
i might go and get myself a sedan diff either way due to the diff whine i have
and they are stronger
Dodgeman
Posted: 2004/3/8 10:28  Updated: 2004/3/8 10:28
Sedan diff? Stronger?
Model for model, the removable third member is identical for sedan & coupe.
If your diferential assembly is faulty, you will need to either get it overhauled, or replace it with a used servicable unit & this may prove to be the practical & economic alternative.
holeshot
Posted: 2004/3/8 11:08  Updated: 2004/3/8 11:08
Check the baffle cones in the axel tubes,each side of the diff center had one of them come lose in my HJ47 TROOPY.
DatA15
Posted: 2004/3/8 11:51  Updated: 2004/3/8 11:51
it shows that the platipus is swimming in diff oil (pretty laim)
Team_Dat
Posted: 2004/3/19 7:53  Updated: 2004/3/19 7:53
Actually dodgeman the sedan diff is a borg warner where as the coupe diff is something from Japan. the borg warner is bigger and stronger.
Posted: 2004/3/19 8:03  Updated: 2004/3/19 8:03
Team_Dat, are you thinking about the 120Y diff? The 1200 diffs sedan or coupe are the same (all Japan-assembled cars).
Dodgeman
Posted: 2004/3/19 14:35  Updated: 2004/3/19 14:35
The Borg Warner rear axle assembly was used in Australian built 120Y's from June 1976. Thats why i wrote "model for model" [imported compared to imported models etc.]
Cars before this date were imports & used the Japanese Diff. Some models were never produced here, so were imported for the full model run & these continued to use the Jap diff.
This diff is an H150 unit, which is a little bigger & stronger than the H145 that was used in the 1200. I don't know the model number for the 1000 diff as it is diferent from the 1200 unit, but is interchangeable none-the-less.
I keep seeing this statement about the Warner diff being so strong, but have yet to see any real evidence that it is true.
From personal experience I can say that they are a real pain to service.
Team_Dat
Posted: 2004/4/1 3:52  Updated: 2004/4/1 3:52
from what i can tell then the 120Y has the same Diff as a 1200 pre 1976 and regardless all the coupes had the smaller H145 but would lik either the ute diff or the 120y sedan or wagon diff built after 1976 for added strength.
Cable_Tie
Posted: 2004/8/5 2:32  Updated: 2004/8/5 2:32
Sedan mounts differntly too the coupe and wagon I'm pretty sure. It is doable though, the shock mounts need modification. Going into a coupe you should be able to chop them off the sedan diff and use the existing mounts on the spring clamp. I dunno, it has been a while, have a good look, i'm pretty sure it is like that.
The ute diff has the brake line on the opoisite to a sedan. An the mounts need to be welded on. I have done this and want to sell it, if you are heading to brisbane that is. . .
Team_Dat
Posted: 2004/8/5 2:39  Updated: 2004/8/5 2:39
i fitted the sedan diff without problem the shock absorber mounts were wrong but i used the coupe U-bolt plates under the leaves instead of the sedan ones so i didn't have to adjust any mounts... i am very happy with my new diff with the much better up high ratio so there is no more 6,000 rpm at 100kmh in 4th. damn rare 5spd's
Mawler1
Posted: 2007/7/11 13:38  Updated: 2007/7/11 13:38
you forgot the VERY early model 120Y's Dodgeman... they ran H145's
I have 3 120Y's a July '74 a July '75, and a March' 77
the July '74 has a H145 not sure if I sohould ditch it for The Defects' BW68...
I have a spare H150 centre but can't be bothered making the 2.5 millimetre spacer
