Main : Members : B120dat Cadet radiator
[<   Previous  65  66  67  68  69  70  71  Next   >]
Cadet radiator
Cadet radiatorPopular
SubmitterB120datMore Photos from B120dat   Last Update2004/3/13 9:07    Tell a friendTell a friend
Hits3188  Comments5    0.00 (0 votes)0.00 (0 votes)
just another view :)
Tudoy
Posted: 2004/3/13 10:09  Updated: 2004/3/13 10:09
Quite a regular
 Re: Cadet radiator
just how "old" is your battery?
B120dat
Posted: 2004/3/13 10:22  Updated: 2004/3/13 10:22
 Re: Cadet radiator
bugger never noticed that see how clean my filters are they will get cleaned tonite
dattodevil
Posted: 2004/3/13 10:57  Updated: 2004/3/13 10:57
 Re: Cadet radiator
nice fit, you might start a trend looks too easy
B120dat
Posted: 2004/3/13 13:29  Updated: 2004/3/13 13:29
 Re: Cadet radiator
it was quite easy in the end, even though the bottom radiator port was on the bottom left a small bit or exhaust tubing did the job.then had to slide the right size hoses over the two ports on the motor (head/block), then slide the bigger hoses over, use some adhesive, then double clamp. the radiator mounted on two plastic legs on the bottom of the radiator, that meant drilling to small holes in the bottom foundation and putting two gromets on the legs of the radiator (acts as cushion). then 2 holes in the top of engine bay support for the brackets with rubber underneath the brackets as well. just go to super cheap and look for the right hose's you will need or cut a longer hose up that has the right bends
it worked out good and has given great results too
DVLDAT
Posted: 2004/3/14 2:15  Updated: 2004/3/14 2:15
 Re: Cadet radiator
good to see the radiator fits mate done a good job hope it works a dream and gets u outer trouble in those stinkn hot days up there.
cheers andrew
