Main : Members : UTE18L UTE-18L
[<   Previous  11  12  13  14  15  16  17  Next   >]
UTE-18L
UTE-18LPopular
SubmitterUTE18LMore Photos from UTE18L   Last Update2004/9/4 7:58    Tell a friendTell a friend
Hits2335  Comments4    0.00 (0 votes)0.00 (0 votes)
need to fix up the air intake and put a bigger throttle, i hear a CA20, or old skyline is a pretty good swap, any ideas???
For all you CA guys i found a site called nissanexa.com, i know i hate the ugly things too, but they came out with FWD CA's so there is a lot of good info there.
datb110
Posted: 2008/3/6 17:33  Updated: 2008/3/6 17:33
Quite a regular
 Re: UTE-18L
Nope a ca20 tb is smaller than a ca 18. an xf tb is something like about 3 inch and can be fitted by just elongating the 4 mounting holes a bit. They come with either a variable resistor or switch type tps sensor so get the right one there or make a plate up to mount the original ca one.
Popular mod for the vl commodore engines but may be a bit too big for a ca and may cause a jerkie throttle responce from off idle but should be good at high revs.
who_your_datty_1200
Posted: 2004/8/27 16:02  Updated: 2004/8/27 16:02
 Re: UTE-18L
Your right that the CA 20 TB is a good way to go.
UTE18L
Posted: 2004/8/27 16:07  Updated: 2004/8/27 16:07
 Re: UTE-18L
who told you or what do you know???
easy install???
who_your_datty_1200
Posted: 2004/8/27 16:18  Updated: 2004/8/27 16:18
 Re: UTE-18L
I think that I read it in a tread some where or was talking to someone about it. All I know is that the CA 20 TB is bigger than the CA18 TB.
