Main : Members Do not use this as a guide
[<   Previous  1378  1379  1380  1381  1382  1383  1384  Next   >]
Do not use this as a guidePopular
SubmitterUTE18LMore Photos from UTE18L   Last Update2004/3/15 22:57    Tell a friendTell a friend
Hits2926  Comments8    0.00 (0 votes)0.00 (0 votes)
very crappy install of a CA18DET
DVLDAT
Posted: 2004/3/16 14:09  Updated: 2004/3/16 14:09
 Re: Do not use this as a guide
holly jesus does it run? looks like everything was done on a tight budget? looks like its gona be forever worked on 2 get it running.
B120dat
Posted: 2004/3/16 14:27  Updated: 2004/3/16 14:27
wasnt this the 1200 that was for sale real cheap on ozdat months ago!!! for like $2000 or 3000???
UTE18L
Posted: 2004/3/16 17:26  Updated: 2004/3/16 17:26
yes it was
Wattage
Posted: 2004/3/16 23:44  Updated: 2004/3/16 23:44
It doesn't look that bad, the fact that all the yellow is showing through the black i nthe engine bay makes it look a lot worse than it actually is.
I should have taken pics of a mates s13 that had a 'custom' front mount fitted to it. Strested radiator hoses were used to join the pipes, and there were even some galvanised water pipes used.....*shudder*
jack
Posted: 2004/3/17 8:42  Updated: 2004/3/17 8:42
Here's the thread: click.
holeshot
Posted: 2004/3/17 10:15  Updated: 2004/3/17 10:15
LOOK AT THE RAD PANEL! WHAT PANEL, D.M.T. wont like that.Thay all so cut the top off to get it in.
B120dat
Posted: 2004/3/17 10:36  Updated: 2004/3/17 10:36
this whole things is stilll a bargin, as long as everything is cosmetic?
if its a low KM CA18det and a decent body then now wurries 2 or 3 grand is a steal. as long as the body is good and the motor etc is good. cause this is a complete Ca ute! yeah it may need 2 or 3 grand pumped into it but then gezze thats a bloody cheap Cadet ute you will have!!
UTE 18L did you get the motor Comp tested etc etc? was it running when you bought it? is this a "Do up job" to sell and make a few bucks or is it gonna be another CA ute to your collection
UTE18L
Posted: 2004/3/17 17:19  Updated: 2004/3/17 17:19
Sold a long time ago, no comp test, nothing, what do you expect for $3000, and it did start when i bought it.
