Main : Misc Bobs1200 master cylinder
[<   Previous  7136  7137  7138  7139  7140  7141  7142  Next   >]
Bobs1200 master cylinderPopular
Submitterbobs1200More Photos from bobs1200   Last Update2002/10/4 15:42    Tell a friendTell a friend
Hits9321  Comments5    0.00 (0 votes)0.00 (0 votes)
280zx master cylinder reverse mounted under dash
b310gx
Posted: 2002/10/6 7:45  Updated: 2002/10/6 7:45
 Re: Bobs1200 master cylinder
must be a pain to top up brake fluid.you could try a remote reservoir filler like on some trucks & vans.
bobs1200
Posted: 2002/10/6 19:57  Updated: 2002/10/6 19:57
The car is used for autocrossing not registered street use. Yes remote resivoir would be easier but it only take a minute to remove dash for access and I've never had to top it off. I flush the system once a year.
Bob
Posted: 2002/10/5 7:40  Updated: 2002/10/5 7:40
OK, I give up. The stock pedal pushes the rod forward ...
Is this cylinder pointing backwards? ... how does the linkage work?
bobs1200
Posted: 2002/10/6 0:11  Updated: 2002/10/6 0:11
I took a master cylinder mount off a 510 and welded it to the top of the steering colum support. I then welded an extension to the top of the brake pedal and made a rod to connect the master cylinder from the brake pedal.
Changing the position of the rod from below pivot point to above changed the direction.
Bob
1200rallycar
Posted: 2002/10/6 3:37  Updated: 2002/10/6 3:37
is it legal in america, it isnt here in australia especially in motorsport
