Main : Misc 130Y
[<   Previous  6314  6315  6316  6317  6318  6319  6320  Next   >]
130Y
130YPopular
SubmitterTommyMore Photos from Tommy   Last Update2004/5/21 11:06    Tell a friendTell a friend
Hits6382  Comments8    9.50009.50 (2 votes)
Just curious if anybody had ever seen one of these before?
ocphangaz
Posted: 2005/6/22 8:33  Updated: 2005/6/22 8:33
 Re: 130Y
That's a Datsun/Nissan Sunny 130Y...
AND it's taken in Malaysia.. that isa Penang's Number plate :p
Dodgeman
Posted: 2005/6/22 4:10  Updated: 2005/6/22 4:10
 Re: 130Y
I can't tell if i have seen one before because i can't see it now. I'm sure it would make a great stamp though.
When i was at the DatNats in Goulburn i saw an L series engine with '1300' cast into the cam cover. I was not aware that a 1300cc L series ever existed, but it looks like they did.
What engine did these 130Y's use?
pro-240c
Posted: 2005/6/22 4:30  Updated: 2005/6/22 4:30
 Re: 130Y
that'd be the L13.
L13
Displacement: 1.296L
CR: ??
Deck Height: 207.85mm
Bore x Stroke: 83 x 59.9mm
Rod Length: 139.9mm
Piston Dish: 0cc
Intake Valve Diameter: 38mm
Exhaust Valve Diameter: 33mm
(specs courtesy of Lurch )
L18_B110
Posted: 2005/6/22 6:06  Updated: 2005/6/22 6:06
 Re: 130Y
yeah, I have a workshop manual for the early L13, L14 and L16 engines. They all share the same block casting with the L18, all 83mm bore with different strokes. I think the L13 and L14 share the same rods, L16 and L18 rods got progressively shorter because of the longer strokes and deck height restrictions of sharing the same block.
There is a guy on the Gold Coast with a beige coloured 1600 2dr and 15" performance challengers on it, with the original L13 block in the car with L18 internals. It may actually have been the car you saw - he went to Datnats. Although its been so long since I saw the car that I can't remeber what rocker cover it had...
Lobster
Posted: 2004/5/23 14:38  Updated: 2004/5/23 14:38
 Re: 130Y
perhaps a bigger picture might make it easier to know...
woodydat
Posted: 2004/5/23 15:14  Updated: 2004/5/23 15:14
 Re: 130Y
ill second that!
Posted: 2004/5/23 18:43  Updated: 2004/5/23 18:43
 Re: 130Y
How do you get a picture so small? No cameras take pictures that small do they?
It looks like it might be a Sentra or Micra/March. Maybe it has the CG13 engine.
sunnyVIP303
Posted: 2005/6/22 2:50  Updated: 2005/6/22 2:50
 Re: 130Y
This is Datsun Sunny B11 start production at 1981 . 1st gen FF sunny with E13 engine
