Main : Misc CA18DET IN
[<   Previous  6215  6216  6217  6218  6219  6220  6221  Next   >]
CA18DET IN
CA18DET INPopular
SubmitterNIS15LMore Photos from NIS15L   Last Update2004/6/19 8:50    Tell a friendTell a friend
Hits2706  Comments5    9.00009.00 (1 vote)
took 15 mins to change the crossmember and 15mins to drop the motor in.
NIS15L
Posted: 2004/6/24 6:14  Updated: 2004/6/24 6:14
 Re: CA18DET IN
thanks for the info chris you learn something new everyday do you think i would still need to do that even tho the tunnel is being cut And made much bigger than original
datlow
Posted: 2004/6/22 9:34  Updated: 2004/6/22 9:34
 Re: CA18DET IN
was that 15 mins from the standard a12 mounts to ca18 mounts ?, just wonderin cause im wantin to put one in an was wonderin how difficult it is!, what diff are you using?
Demojob
Posted: 2004/6/22 10:07  Updated: 2004/6/22 10:07
 Re: CA18DET IN
He would of had another cross member made up to suit, because if it took him 15mins to make up the new mounts I'd be worried to drive this thing. The conversion isn't the hardest conversion but don't think it's a weekend job, it take MANY!!!! hours...... and money
Damo
go_the_datto
Posted: 2004/6/22 10:49  Updated: 2004/6/22 10:49
 Re: CA18DET IN
ahh yes but lets see it get put in in 15 mins with a gearbox and that lovely shiny paint not get scratched
looking great so far, will be keen to see more pics as you go
,cheers
NIS15L
Posted: 2004/6/24 2:51  Updated: 2004/6/24 2:51
 Re: CA18DET IN
the 15 mins to unbolt old crossmember and put maddat crossmember in and i installed motor seperate from gearbox so i didnt scratch the paint tunnel is not made yet so gearbox doesnt fit yet.
Putting the motor is the easy part of a ca conversion ask anyone who has done it and im sure they will agree.
Im running standard ute diff for now.
Cheers Luke
dattodude
Posted: 2004/6/24 6:06  Updated: 2004/6/24 6:06
 Re: CA18DET IN
You have put the engine in the way I would recommend. However, I recommend dropping the steering assembly from the pitman arm, and disconnect the trailing arm from the chassis, then undo the 4 bolts that hold the crossmember on, and lower the engine and crossmember. This makes putting on the gearbox, a much easier process.
Putting the engine in is easy'ish (especially with a fitting kit).
It's all of the wiring and space planning for where all the electricals and relays/fuses etc are going to go that is difficult.
It's the "amount of work and small jobs" that makes this a difficult process.
Chris
