Main : Mechanical : Wheels  wheel studs and spacers
[<   Previous  186  187  188  189  190  191  192  Next   >]
wheel studs and spacersPopular
Submitter_steve_More Photos from _steve_   Last Update2004/6/29 12:24    Tell a friendTell a friend
Hits4037  Comments9    0.00 (0 votes)0.00 (0 votes)
2 fit new car rims
_steve_
Posted: 2004/7/3 3:16  Updated: 2004/7/3 3:16
 Re: wheel studs and spacers
HAVE A LOOK AT MY RIMS NOW
_steve_
Posted: 2004/7/1 12:32  Updated: 2004/7/1 12:32
i got them 4 $300 the lot
and the spacers ar 28mm
_steve_
Posted: 2004/6/29 12:39  Updated: 2004/6/29 12:39
i can fit new rims from the newer cars
feral
Posted: 2004/6/29 13:30  Updated: 2004/6/29 13:30
OK!
But what has it done to your handling and braking??
With the rim offset that much, scrub radius would be horrendous unless you were running negative offset FWD rims.
Show us a pic with some rims on when you can?
datman55
Posted: 2004/6/30 0:52  Updated: 2004/6/30 0:52
How thick are those spacers, what do they cost and where can you get them?
I am planning on running some late model wheels on the race car, but I need about a 20mm spacer.
Errol, do you mean late model wheels with positive offset?
In my example, I have 14x7's (offset -3), I am going to a 15x7 (offset +17) so I need a 20mm spacer to put the tyre back where it is now.
From what I understand, if it's a negative offest, you get the "deep dish" effect, positive offset is the opposite (how most FWD cars are set up)
Regulator
Posted: 2004/6/30 9:24  Updated: 2004/6/30 9:24
Dont ya get busted by da wof and the 5-0 4 addn spacers?
feral
Posted: 2004/7/1 13:24  Updated: 2004/7/1 13:24
The way I understand it is -
Positive offset is away from the hub flange towards the out side of the vehicle. Negative offset is back toward the hub.
Wheels with a +15 offset give a wider track than +5 offset.
datman55
Posted: 2004/7/2 8:40  Updated: 2004/7/2 8:40
Thanks Steve, I thought they looked pretty chunky!
Errol - I agree about the firts part of what you said - Positive offset puts the flange face further toward the outside of the wheel. This being the case - assuming the width of the wheel is the same - then more of the wheel must hang inboard on the car.
As I understand it, a "deep dish" wheel,which has a negative offset (flange towards the inside of the rim) would then give a wider track, as more of the rim is "hanging" out, away from the hub.
for example, on my car (Datsun Sunny with H190 diff), the diff is much wider than the standard diff. We have added flares which cover the wheels, however I want to go from 7" - 8" rims, but I want the extra inch back towards the inside of the car. To achieve this, we theoretically move the mounting flange in the rim further towards the outside of the rim (positive offset), meaning more of the wheel is hanging inside the car.
I hope that makes sense.
Posted: 2004/7/2 16:37  Updated: 2004/7/2 16:37
So as long as the spacers keep the offset reasonable (or if they 'correct' wheels with too much positive offset), they won't cause any handling/wear problems.
Wheel Offset and Backspace Diagram
oldmate
Posted: 2004/6/30 0:15  Updated: 2004/6/30 0:15
where did you get the spacers from steve, ive been looking for the same thing
