Main : Misc Carbyyy
[<   Previous  6063  6064  6065  6066  6067  6068  6069  Next   >]
Carbyyy
CarbyyyPopular
SubmitterselfwedgeMore Photos from selfwedge   Last Update2004/8/2 9:29    Tell a friendTell a friend
Hits3592  Comments5    0.00 (0 votes)0.00 (0 votes)
Dont know what type carb it is.
ockie
Posted: 2004/10/3 19:05  Updated: 2004/10/3 19:05
 Re: Carbyyy
Get some SU's. Works great on my Pulsar 1400.
Posted: 2004/10/3 21:18  Updated: 2004/10/3 21:18
 Re: Carbyyy
My hitachis (like in the photo) are going strong after 200,000 kilometers. Very smooth carb. Don't throw it away unless it is broken.
Dodgeman
Posted: 2004/10/3 22:43  Updated: 2004/10/3 22:43
 Re: Carbyyy
There is nothing wrong with these Hitachi carbs. They are well designed, quite well made & are well suited to their intended application. I have seen them with many hundreds of thousands of of K's on them still performing well.
I am curious to know what was so badly worn on the South African examples that rendered them both unservicable & unrepairable while at 40,000k, the vehicle would have been only just out of warranty.
If what looks to be a broken air filter stud is replaced, & the carb is properly serviced, it will likely give many years of satisfactory service in its intended application.
I suspect that the dud carbs previously mentioned have an owner problem, ... not vice versa.
bones
Posted: 2004/8/3 16:10  Updated: 2004/8/3 16:10
 Re: Carbyyy
It is indeed the Hitachi as mentioned, they come standard on the South african 1400 utes, A14S motor. Now do yourself a favour and toss that carb as far away as you can. the last 3 1400 utes that I have owned had them wear out after 40000km odd.
Regulator
Posted: 2004/8/3 0:21  Updated: 2004/8/3 0:21
 Re: Carbyyy
Ouch...Repco sells de-graser for $2.00 at the mo....hint hint
Posted: 2004/8/2 16:51  Updated: 2004/8/2 16:51
 Re: Carbyyy
It looks like a Hitachi 306. It should have the number stamped on the flat plate shown in the top of the picture.
