Main : Members : dat16 E15 dissy 13
[<   Previous  3  4  5  6  7  8  9  Next   >]
E15 dissy 13
E15 dissy 13Popular
Submitterdat16More Photos from dat16   Last Update2004/8/29 14:05    Tell a friendTell a friend
Hits3646  Comments11    0.00 (0 votes)0.00 (0 votes)
Yes the vac advance sits very close to the head but has enough movement for adjustment,(A bit more on the advance side though)
simmodat1200
Posted: 2004/8/31 11:51  Updated: 2004/8/31 11:51
 Re: E15 dissy 13
what does it go like now with electronic installed?
Lobster
Posted: 2004/9/1 15:53  Updated: 2004/9/1 15:53
 Re: E15 dissy 13
good question
dat16
Posted: 2004/9/2 3:53  Updated: 2004/9/2 3:53
 Re: E15 dissy 13
Surprisingly not that different....
Starts a bit easier and seems to build up revs a touch quicker, but other than that not much...
I haven't had time to put in new plugs and leads yet so I will get back to you...
Remember though that this is not an "high energy" unit like the bluebird one, just a plain old electronic dissy with no points to worry about..
Posted: 2004/9/2 7:19  Updated: 2004/9/2 7:19
 Re: E15 dissy 13
I think all the E-series distributors are high-energy, being they are from the 1980s. The early electronic distibutors (circa pre-1978) used a ballast resistor. Generally speaking, if it doesn't use a ballast resistor it is 'high energy'.
converted
Posted: 2004/9/2 7:26  Updated: 2004/9/2 7:26
 Re: E15 dissy 13
I have just put a high energy electronic ign on my A-series and it starts with just a small touch of the starter button and quick prime of the twin webers. The biggest difference will be that it will be much more able to keep reliable timing and spark at high rpm such as 7000-9000 rpm... its probably the most significant thing as far as perfromance you can do to your engine after putting twin webers on it....
converted
Posted: 2004/9/2 7:28  Updated: 2004/9/2 7:28
 Re: E15 dissy 13
teretonga
Posted: 2004/9/2 9:17  Updated: 2004/9/2 9:17
 Re: E15 dissy 13
Would the high energy ign help if the plugs were bad Converted? How long would you have to lean on the starter then do you reckon? Roughly how many volts do you think would be passed through the human body if someone held onto a lead while your high energy ign was cranking? A ball park figure not necessarily based on your own experience would be acceptable.
woodydat
Posted: 2004/9/2 12:37  Updated: 2004/9/2 12:37
 Re: E15 dissy 13
hmm i think teratonga is trying to tell us something???
dazzasute
Posted: 2004/9/2 13:15  Updated: 2004/9/2 13:15
 Re: E15 dissy 13
This kinda reminds me of this joke... kinda off topic, but its sorta related
test for Ignition Output:
Hold medium wrench in one hand, Sears wrench preferred for accuracy
of test 'cause other smooth wrenches are too slick for throwin'!
With engine runnin', grab hold of the plug end of an ignition cable with the other hand
and hold on tight!
This will more than likely cause you to throw wrench! KV output is based on how far
the wrench wuz thrown!
10 feet =
approx. 10,000 volts
20 feet =
approx. 15,000 volts
30 feet =
approx. 25,000 volts
Over 30 feet =
Caution! Must be one of them new
dis-is-it ignition systems, use bigger
wrench and retest.
Electricity will not usually hurt you, instead it is the back of
your neck going through the hood latch that really ruins your day!!
phunkdoktaspok
Posted: 2004/8/30 11:24  Updated: 2004/8/30 11:24
 Re: E15 dissy 13
Thats why you modify the mounting plate not the dissy, so the vacumn advance doesnt foul on the engine.
Either way aslong as it works.
The original black wire from the dissy is the one that went to the negative side of the coil. Either take it off or just tape it up and foget about it.
Cheers Steve
dat16
Posted: 2004/8/30 12:55  Updated: 2004/8/30 12:55
 Re: E15 dissy 13
With lack of any experience on a welder I found it easier to modify what I had rather than enginier something new..As you say, either way it still works.Thanks for the info on that wire,I assumed that was what it was for just wanted to be sure..
