[< Previous 649 650 651 652 653 654 655 Next >]
Rear tunell mods
ca18det_man 2006/7/1 18:12 Tell a friend
3449 1 9.00 (1 vote)
| The S13 box is heaps longer than the standard box and quite wide at the rear too. Ive made metal plating up to cover this just need to weld it all up. |
| Poster |
Thread |
| mad120y |
Posted: 2006/7/1 19:13 Updated: 2006/7/1 19:13 |
Home away from home   Joined: 2004/4/14 From: Posts: 371 |
 Re: Rear tunell mods nice,for some reason i thaught it would have sat further back... Did your old r30 box come up through the stock hole?
| Poster |
Thread |
| converted |
Posted: 2006/7/2 3:23 Updated: 2006/7/2 3:23 |
No life (a.k.a. DattoMaster)   Joined: 2002/6/7 From: Newscastle, Australia Posts: 2479 |
 Re: Rear tunell mods Hi yes the stumpy skyline box would come up through the factory cut hole, and is a good box for the street for an N/A or stock turbo CA18/SR20 (bellhousings can be swapped to suit). I use the R32 GTS-T box (with SR20), stronger again than Andrews silvia S13 box and also shorterI only have to cut about 40mm out of the standard hole for the gear stick to come through....
