[< Previous 92 93 94 95 96 97 98 Next >]
Switch panel wiring
datman55 2004/10/4 7:05 Tell a friend
1942 7 0.00 (0 votes)
| A good look at the wiring on the switch panel. The switch panel and dash are on seperate looms which can be disconnected and removed by one or two plugs. |
| Poster |
Thread |
| datman55 |
Posted: 2004/10/4 7:24 Updated: 2004/10/4 7:24 |
Home away from home   Joined: 2003/10/28 From: Perth Posts: 848 |
 Re: Switch panel wiring Pic of the wiring that is behind the switch panel. I'm gald I had an expert do it all for me!
| Poster |
Thread |
| kegs |
Posted: 2004/10/4 11:16 Updated: 2004/10/4 11:16 |
No life (a.k.a. DattoMaster)   Joined: 2003/1/5 From: campbelltown (sydney) australia Posts: 1802 |
 Re: Switch panel wiring the connector at the top right corner looks like one of the plugs at work we charge our forklifts with.... wat is it for ???
| Poster |
Thread |
| datman55 |
Posted: 2004/10/4 13:05 Updated: 2004/10/4 13:05 |
 Re: Switch panel wiring That's too allow us to disconnect the switch panel quickly if we need to. That plug is for the main battery feed..... hence the heavy duty cable. saves us having to disconnect the battery from the main power switch unde the switch panel.
| Poster |
Thread |
| kegs |
Posted: 2004/10/4 13:28 Updated: 2004/10/4 13:28 |
 Re: Switch panel wiring good idea, i spose if its just a 12v cable quick adapter then its probly the same thing u find on forklifts.
| Poster |
Thread |
| datman55 |
Posted: 2004/10/4 14:08 Updated: 2004/10/4 14:08 |
 Re: Switch panel wiring It does look very similar...maybe a little smaller than the Forklift ones though...but not much ;)
| Poster |
Thread |
| ca18det_man |
Posted: 2004/10/7 11:15 Updated: 2004/10/7 11:15 |
No life (a.k.a. DattoMaster)   Joined: 1999/11/25 From: Mudgee NSW Australia Posts: 1187 |
 Re: Switch panel wiring Awesome job !!! I can only hope mine turns out half as good as that. I see teh many hours have gone into the car when do you think it will be ready to go?? Next season maybe
| Poster |
Thread |
| datman55 |
Posted: 2004/10/7 23:52 Updated: 2004/10/7 23:52 |
 Re: Switch panel wiring I should be testing early in the new year...assuming I can organise to get my CAMS licence renewed, I should be at Round 1.
