Main : Mechanical : Body and Interiors Dash Wiring (left side)
[<   Previous  4246  4247  4248  4249  4250  4251  4252  Next   >]
Dash Wiring (left side)Popular
SubmitterddgonzalMore Photos from ddgonzal   Last Update2004/10/25 16:56    Tell a friendTell a friend
Hits8562  Comments2    0.00 (0 votes)0.00 (0 votes)
1972 North American (LHD model)
1 - Tach terminals on back of speedometer (for factory tachometer)
2 - Green wire to Hazard flasher
3 - Blue wire (always hot) for optional Clock. This is originally taped to the harness with blue tape
4 - To turn-signal/Hazard switch on steering column
5 - To headlight Dimmer switch on column
Posted: 2004/10/25 5:24  Updated: 2004/10/25 5:24
 Re: 1972 North American dash wiring (left side)
Warning buzzer is for the "Fasten Seat Belt" buzzer. For 1972-73 there is also a lamp on top of dash. Switch is grounded through the driver's door switch.
Any suggestions on how to wire the tachometer? I think I can use the blue wire and the two factory tach terminals on the speedo housting.
Tach in picture is a first-gen Celica unit. It is held in by the two factory screw-holes near speedometer (not seen in photo). The screw holes on the visible side do not line up. Wiring is as follows:
Yellow - to coil '-' terminal
Black - ground
others - lights in tach
