[< Previous 423 424 425 426 427 428 429 Next >]
1200 vs sunny struts (part1)
Z-U 2004/10/29 14:23 Tell a friend
5824 1 0.00 (0 votes)
sunny part locations: strut = left, disc = bottom, caliper = bottom, rubber mounted trust bearing = right.
as you can see the sunny strut is just like a heavy duty version of the 1200 unit.
(note: the sunny strut is off a sunny P/Van, so it could be different to a standard one?)
| Poster |
Thread |
| ddgonzal |
Posted: 2012/5/19 6:10 Updated: 2012/5/19 6:10 |
Moderator   Joined: 2001/5/3 From: Kent, WA Posts: 31866 |
 Re: 1200 vs sunny struts (part1) There are two B310 (Sunny) struts: 45mm on A12-powered B310 (same diameter as 1200) 2.0 inch on A14/A15-powered B310
The one here looks like the larger diameter strut.
