Main : Misc Datto after a good blastin
[<   Previous  5825  5826  5827  5828  5829  5830  5831  Next   >]
Datto after a good blastinPopular
SubmitterDatto_KingMore Photos from Datto_King   Last Update2004/11/6 11:48    Tell a friendTell a friend
Hits2810  Comments7    0.00 (0 votes)0.00 (0 votes)
just got the coupe sand blasted, almost there
Datto_King
Posted: 2004/11/7 9:55  Updated: 2004/11/7 9:55
Quite a regular
 Re: Datto after a good blastin
The guy who sand blasted it used very fine high quality imported sand and the sill tht is hiding is not tht bad just some small holes but i,ve already got new sills made up so its fearly straight.
oh yeh Blair the back end turned out to be quite clean and straight
A14force
Posted: 2004/11/6 19:41  Updated: 2004/11/6 19:41
I have heard that sand blasting distorts panels .
mikali
Posted: 2004/11/6 23:25  Updated: 2004/11/6 23:25
Sand blasting can distort panels depending upon thickness and type of metal used in the panels, ive seen this first hand. If you really want to blast your car clean of paint and rust the best way to do it nowadays is by walnut shell blasting. It supposedly involves less friction and is better for cars with thin panels.
who_your_datty_1200
Posted: 2004/11/6 12:03  Updated: 2004/11/6 12:03
How did you get on with your rear end???
Where do you get it blasted??
Frodaddy
Posted: 2004/11/6 12:15  Updated: 2004/11/6 12:15
Why sand blast?
Datto_King
Posted: 2004/11/7 10:02  Updated: 2004/11/7 10:02
Quite a regular
only way to remove rust completely, the sand blaster did not blast square onto panels but blasted at an angle to reduce friction and pressure
B110SSS
Posted: 2004/11/8 0:21  Updated: 2004/11/8 0:21
I asked that same question 12 years ago when I was faced with the restoration of the SSS. The answer is that all is laid bare for you, all the inner door frames and those fiddly bits that you simply can't effectively get at to rub back - all stripped back to bare metal and once painted giving you back that nice, crisp, sharp look of a new car!
However it can be a pretty demoralising exercise, I have seen some absolute shockers that looked fine prior to being blasted and once the paints off and the bog gone one is left to ponder on 'what the hell have I done!
It definitly is worth it though.
And for that matter if you are getting keen bead blasting all suspension components is great too. Quick and clean- 30 + years of dirt and whatever just wiped off leaving a nice porous surface that just sucks up black gloss to give a very nice, as new finish.
Cheers
Dave
dazzasute
Posted: 2004/11/6 15:21  Updated: 2004/11/6 15:21
if thats just been sand blasted, it looks like you've got yourself a pretty decent shell there....
although the trailer ramps look like their hiding a fair bit of rust in the sill
Datto_King
Posted: 2004/11/7 9:58  Updated: 2004/11/7 9:58
Quite a regular
Howard Barnes he's a real good guy to deal wth. knows wht he's doin too
who_your_datty_1200
Posted: 2004/11/7 10:00  Updated: 2004/11/7 10:00
I will try to get down your way once Monty's finished to see how the coupe is looking
