Main : Members : go_the_datto the box with the lid of it
[<   Previous  10  11  12  13  14  15  16  Next   >]
the box with the lid of itPopular
Submittergo_the_dattoMore Photos from go_the_datto   Last Update2002/11/8 10:52    Tell a friendTell a friend
Hits8872  Comments7    0.00 (0 votes)0.00 (0 votes)
here is the throttle set up insinde the box
phunkdoktaspok
Posted: 2002/11/8 12:54  Updated: 2002/11/8 12:54
 Re: the box with the lid of it
I see what you are talking about with the accelerator!
And I never thought about actually welding in a bit of pipe for the fuel line!
( Smart thinking!)
But how the F@#k did you do up the four ten mill nuts for the carbie?
( Their bad enough even without a box especially if you don't have short spanners on you at the time!)
go_the_datto
Posted: 2002/11/10 11:41  Updated: 2002/11/10 11:41
Its not as bad as it looks to get to the 10 mm bolts at the base of the carby there is only one that is a bit hard to get to.
I bent a 10mm spanner up just for the job
phunkdoktaspok
Posted: 2002/11/10 11:55  Updated: 2002/11/10 11:55
I will have to remember that trick!
bent_axel_bob
Posted: 2002/11/11 0:29  Updated: 2002/11/11 0:29
ok this is probly a dumb question but ya should be used to em cummin from me ok so how is it sealed where the throtle cums throu the box
phunkdoktaspok
Posted: 2002/11/11 0:48  Updated: 2002/11/11 0:48
Bob it's not a dumb question as I asked Go the Datto the same one and he explained that he has a nut welded to the out side of the box! through this a bolt runs to the carbies throtle and is joined some how!
( not sure how he said)
On the out side he has the part that the cable runs off connected to this bolt!
so it is actuated from out side the box!
If you want to check how Go the Datto described it he did back in one of the forums!
( I will go and check which one and PM it to you!)
bent_axel_bob
Posted: 2002/11/11 1:09  Updated: 2002/11/11 1:09
cheers mmm it looks real simple and now i know how its been done i might atemt it maybe one day
go_the_datto
Posted: 2002/11/11 12:33  Updated: 2002/11/11 12:33
inside the box the thread joins to the throttle shafts via a basic uni sort of arangment.
Like the 200B mechanical throttle linkage
