Main : Members : 1200rallycar mounting block diagram
[<   Previous  107  108  109  110  111  112  113  Next   >]
mounting block diagramPopular
Submitter1200rallycarMore Photos from 1200rallycar   Last Update2002/11/11 3:13    Tell a friendTell a friend
Hits4357  Comments1    0.00 (0 votes)0.00 (0 votes)
If you have a 1200 and want to put in a 120y a-12 or an a-14 or a-15 from another car you will need to have blocks like these to mount the motor to your original mounts
they sit flat in the engine bay with one end (hole 25 mm from edge) on the engine mount with the other hole further back and inward in the engine bay, this hole is used for the mounting on the block of the engine which will bolt down straight through it.
1200rallycar
Posted: 2002/11/11 3:14  Updated: 2002/11/11 3:14
 Re: mounting block diagram
thar she blows!!
sorry it took so long, i hope this saves you a lot of time
