Main : Members : kegs another view of my dellorto's and custom airbox
[<   Previous  100  101  102  103  104  105  106  Next   >]
another view of my dellorto's and custom airboxPopular
SubmitterkegsMore Photos from kegs   Last Update2005/1/5 1:03    Tell a friendTell a friend
Hits2445  Comments6    0.00 (0 votes)0.00 (0 votes)
what you guys think? i still need to fix up my linkages.
datsik
Posted: 2005/2/1 14:34  Updated: 2005/2/1 14:34
 Re: another view of my dellorto
looks awesome...should polish the stainless.
kegs
Posted: 2005/2/1 14:43  Updated: 2005/2/1 14:43
im more worried about spending money on getting the engine in the car once its a few days before ready to go in ill start making it all look pretty.
datman55
Posted: 2005/2/1 22:25  Updated: 2005/2/1 22:25
Looks great dude.
tsillay
Posted: 2005/2/2 1:30  Updated: 2005/2/2 1:30
it's all good
hey what make is the manifold?, I'm accustomed to the kind that has a single mounting bolt between the intake runners, eg, a bolt between 1&2 inlet and a bolt between 3&4 inlet, not bolts on the outside of the 1/2 and 3/4 combo...
Frodaddy
Posted: 2005/2/2 4:49  Updated: 2005/2/2 4:49
That kind of single bolt pattern is the A12 head pattern and the one of kegs is for an A12GX, A14 or A15 with two bolts per runner.
b310gx
Posted: 2005/1/8 5:40  Updated: 2005/1/8 5:40
firstly,get a linkage to join the two carbies,these are available from carby services
in burwood sydney.you can then use one bar from the rod to the carbies.this will help in balancing the carbies,very important for proper running.then,get the throttle cable plate off a 1200 carby to attach the cable to that rod.just braze it to the rod.there are photos of the set up i have on my a15 on the site,just look under
'more photos from b310gx',& sort through them,cause i can't remember where they were
stored.this might help you.sorry if the photos are a bit dark,i'm a lousy photographer.
