Main : Misc My dash
[<   Previous  5693  5694  5695  5696  5697  5698  5699  Next   >]
My dash
My dashPopular
SubmitterFreakMore Photos from Freak   Last Update2005/1/18 8:17    Tell a friendTell a friend
Hits2851  Comments6    0.00 (0 votes)0.00 (0 votes)
Dash with new stuff
Freak
Posted: 2005/1/18 8:20  Updated: 2005/1/18 8:20
 Re: My dash
Done everything I want to it now. New steering wheel, gear knob + i added temp and oil pressure guage. Also that little switch is for my thermo fan. I didn't want to spend $50 on the kit to make it come on automatically.
ISL33P
Posted: 2005/1/18 8:24  Updated: 2005/1/18 8:24
 Re: My dash
i notice yours also has the dip in the middle of the dash like mine does.
is this something that happens with all of them?
Freak
Posted: 2005/1/18 9:50  Updated: 2005/1/18 9:50
 Re: My dash
I've seen it on others to. Its probably just the sun warping the centrepiece.
evilsim
Posted: 2005/1/18 13:33  Updated: 2005/1/18 13:33
 Re: My dash
the dash looks good ! im using an oil pressure guage too, it always sits on 100+ unless its cold and idling badly, when the guage can drop to 40 or more..(till i rev) does yours do much the same? the good oil pressure i assume means a good oil pump...
you may want to reconsider the thermo switch, i found one at picknpayless once for $15. i rekon they are worth it ; i would quickly forget to notice my temperature as i need to be alert for moronic sydney drivers. also sydney = traffic/lights all the time = overheating.
dattodude
Posted: 2005/1/19 2:44  Updated: 2005/1/19 2:44
 Re: My dash
when buying thermo fan rheostats second hand beware!!!
If the small diameter copper tube gets bent enough, it can develop fine cracks, and the liquid inside leaks out..The fans won't come on.. and your warm and fuzzy feelings of safety will be worthless, except to help you cope with replacing the headgasket, and/or head after the engine blows it's top, on a steep hill, in the middle of summer, a million miles from a telephone.
Buying them new is the best idea. They are less than $50 from memory.
You could pull the bimetal switch in a 240V sliced bread toaster, and use that and a relay if you are really desperate.
Freak
Posted: 2005/1/19 3:48  Updated: 2005/1/19 3:48
 Re: My dash
Thanks about the dash. My oil pressure is up around 70 (maybe more)or so when up it and idles at about 15psi when hot. With the thermo switch I just leave it on when driving around normally so I dont forgret if I stop somewhere and I just turn it off when cruising on an open stretch of road.
Cable_Tie
Posted: 2005/2/22 3:43  Updated: 2005/2/22 3:43
 Re: My dash
Another cheap way of "automating" your thermo fan can be seen at the bottom of the following page:
A Cooling Page
The thermostat as pictured "was" picked up at Dick Smith. They come in a variety of temperatures and Normally Open or Normally closed configurations.
I know RS Components can supply them still.
Otherwise, newer cars have these switches located in the radiators in some cases. You still have to mount it somehow though.
shaun
Posted: 2005/2/22 6:03  Updated: 2005/2/22 6:03
 Re: My dash
i got that same switch the other day for my thermo only differance is i put mine where the choke cable usually goes
