Main : Members : datman55 Dyno Report
[<   Previous  67  68  69  70  71  72  73  Next   >]
Dyno Report
Dyno ReportPopular
Submitterdatman55More Photos from datman55   Last Update2005/2/4 9:59    Tell a friendTell a friend
Hits1861  Comments3    0.00 (0 votes)0.00 (0 votes)
First Dyno report for the Sunny....a bit down on Horsepower, justhappy everything stayed together.
datman55
Posted: 2005/2/4 10:16  Updated: 2005/2/4 10:16
 Re: Dyno Report
Here it is guys...the first dyno report for the Sunny. Approx 183rwhp @6,000rpm on about 15psi.
It was a case of bitter sweet really. I had hoped to get about 200hp at the rear wheels in it's curent state, we fell a little short of that. The good news though, is that the engine held together and did everything right. No nasty noises, spluttering or coughing. All the temps stayed right where they should be and everything sounded great. We have one or two small oil leaks which I will address over the next little while, but certainly nothing serious.
This first tune has given us the information we needed to plan the development of the engine. Essentially the plan is to develop it now in three steps.
1. Replace current camshafts with Standard factory turbo camshafts.
2. Replace turbo charger with something more suitable for our application.
3. Add a water injection system.
Our biggest challenge is the 36mm restrictor which is bolted to the front of the turbo, as soon as the revs hit just over 6,000rpm it hits a wall, and the worm turns back down. Combine this with full boost coming on about 3,800rpm, and the cams really startiong to work at about 5,000rpm the whole thing is all happening too late. When you look at the graph, the car is making great power then all of a sudden hits a ceiling. This is the same thing that a number of other competitors have noticed with the restrictor 6,000 - 6,500rpm is about all that you can use.
The goal is to effectively wind on more boost lower in the rev range...we want full boost by 2,500rpm....so by putting back in the standard cams and selecting a turbo with the right specs, we should be able to achieve this. The turbo needs to have a smaller exhaust housing, but a larger compressor housing....this way it can produce more boost much earlier.
The water injection system will allow us to advance the timing by around 5 or 6 degrees, this alone willgive us a good increase in power.
The bottom line is that I am happy with the result, essentially because nothing went wrong (or bang!). I just have an engine with parts which would work fantastically well if I didn't have a restrictor in place. As this is how I bought the engine, and this is the first time I have run it, I now have a base line to start working from......let the development begin. Before I start ripping anything apart though, I am going to take it to the track and have some fun...including the Datsun Nationals. I have been waiting to drive the car now for over 2 years....so I think I will wait a few months before I pull it all apart and start the chase for more horsepower.
Feel free to make any comments or suggestions.
Mark.
LAGWAGON
Posted: 2005/2/4 11:54  Updated: 2005/2/4 11:54
 Re: Dyno Report
damn that restrictor!!!!!!!! its really a whole new ball game with that in place, chasing power with max of 6000rpm. i dont envy you! its like watching the olympics 100m mens sprints with everyone wearing solid steel jox... take them off and they'd be goin a lot faster... its definately a good idea to enjoy it as it is, will probably help you sort out all those little bugs that always seem to come out of a fresh build. see you at datnats, i'm toiling away feverishly to be ready.
Dodgeman
Posted: 2005/2/4 13:04  Updated: 2005/2/4 13:04
 Re: Dyno Report
It looks like you have a plan, a good plan.
Development is the name of the game & your plan to boost the output at lower rpm is, in my view, the right way to go.
If you play with the shape of the hole in the restrictor, you can pick up some airflow there too, but then, i'm sure you know that already.
How thick is the restrictor plate? even half an inch thick will give you something to work with.
More power to you.
Chris
datman55
Posted: 2005/2/4 19:30  Updated: 2005/2/4 19:30
 Re: Dyno Report
In some ways it's really interesting, you have to use your brain to try and figure how to beat the problem. The goal is 240rwhp, so we are about 55hp off that at the moment. From what I understand, the 240hp figure is about the maximum we can get with the restrictor in place. No matter what we do, we won't get any more peak Horse power.....but we can certainly produce a bucket load of torque!
The guy who did the tuning has a lot of experience tuning turbo cars with restrictors. He was impressed with the way it made power once it hit boost etc, so much so he called it the light switch! He said it should be fun to drive (read difficult to drive fast) and that I will be very busy changing gears to keep it in the right power range....but hey....as long as it's fun...I just want to enjoy it now for a little while.
I hope to have the above plan completed by November, that's when Our National Championships are being held down in Adelaide...and we will certainly need the extra power if we are going to be anywhere near competitive.
