Main : Members : 1200rallycar Fuel pressure regulator
[<   Previous  92  93  94  95  96  97  98  Next   >]
Fuel pressure regulatorPopular
Submitter1200rallycarMore Photos from 1200rallycar   Last Update2002/11/12 14:13    Tell a friendTell a friend
Hits4210  Comments5    0.00 (0 votes)0.00 (0 votes)
this is a fixed value one, i am running constant 3psi pressure because i dont have turbo, there is no return to tank this is not required with these
barpk
Posted: 2002/11/12 15:40  Updated: 2002/11/12 15:40
 Re: Fuel pressure regulator
what type of fuel pump r u using? which car was it taken out from? what is the Max PSI it is making?
barpk
1200rallycar
Posted: 2002/11/13 0:56  Updated: 2002/11/13 0:56
all that info is in the elec fuel pump pic
Quinn
Posted: 2002/11/13 11:45  Updated: 2002/11/13 11:45
where did you get it from and how much was it?
1200rallycar
Posted: 2002/11/13 12:07  Updated: 2002/11/13 12:07
automotive place near me, mainly do tune ups and dyno work, $54
phunkdoktaspok
Posted: 2002/11/13 12:27  Updated: 2002/11/13 12:27
I have seen this type of reg on alot of rotories that I have worked on!
( only when they have had webbers!)
maybe you could try a shop that does these or one that does alot of webbers!
( It's not needed if you just have a standed fuel pump! )
